    Animation file problem.
    3 Posts 2 Posters 230 Views 2 Watching
      timglass
      When I play my Sketchup animation it cuts off the edges of the scenes, how do I correct this? Thanks for your help.
        Well, SU can export in two, different aspect ratios: 4:3 and 16:9. Now in most cases, your SU window is not set exactly to these aspect ratios so SU will crop the visible area to fit these aspect ratios. The only way to see what is on your window when setting up scenes is to resize your window to match either of these aspect ratios. I understand however that this may have a dramatic effect on your toolbar positions.
          timglass
          Okay, thanks for your reply. How and when do I resize the SU window to WYSIWUG?
