    Adding mist
    Scheduled Pinned Locked Moved Post Processing
    9 Posts 9 Posters 9.8k Views 9 Watching
      davidh
      Attached is a step by step for creating mist:
      1.create a new layer called mist and paint on with a white brush the extent of the mist
      2.add a motion blur horizontally
      3.add a motion blur vertically
      4.duplicate the mist layer
      5.use filter render/difference clouds
      6.the second last image shows the difference clouds layer and the mist layer turned on
      7.the last image shows only the difference layer turned on.
      TIP:If you have added vegetation entourage by layers you can move the mist layer up or down to show the mist disappearing behind some elements and covering others.
      • Rich O BrienR Online
        That's an excellent technique πŸ‘
        • daleD Offline
          dale
          Just wanted to say how much I appreciate these tutorials. I use PS in post pro all the time, (usually due to time constraints) and your examples are really useful to me.
          Thanks.
          • boofredlayB Offline
            boofredlay
            Fantastic.
            • Chris FullmerC Offline
              I like that one a lot David. I'll see if I can use it somewhere in the future and post an example.
              I don't live in a snowy area or do much in the snow, so many of the snow tutorials are lost on me πŸ˜„ BUT I do get some awesome fog here in my town. Thanks!,
              Chris
              All my Plugins I've written
              • Bob JamesB Offline
                Bob James
                Much appreciated.
                Indeed we do have fogon the California coast, but there are areas that are blessed with just mist πŸ˜„
                • pbacotP Offline
                  Thanks David, I will have to repeat the process to actually understand what you did here. Here's a thought when I saw your image. I see the sun peaking out in the picture...a challenge would be to hit part of the mist with some color?
                  Here is a picture I took on vacation. Your sun is not so bright, but it's the same idea.some sun rays hitting mist
                  I'm a little embarrassed to share here but to play along, here is an attempt with a picture of mine. Not a rendering but only one I have that has water. I found that I had to paint in the colored mist as a second process, similar to the first. I couldn't get a shaft of light affect. Probably wouldn't work at this scale FOV anyway. Then I had to add some flares and make a quick effect into a great bother πŸ˜’ an attempt
                    jsmith
                    WOWSER!
                    • Z Offline
                      zapwizard
                      So perfectly simple. Great tutorial.
