    New to dynamic compnent, please help !
    3 Posts 2 Posters 484 Views 2 Watching
    • K Offline
      karnalta
      Hi all
      I am new to dynamic component and I am facing a problem, I hope you will be able to help me out.
      I am trying to do a dynamic frame with 45 degrees junctions. I have successfully fixed the width of the frame border, but when I change the size of the frame, my 45 degrees junctions are messed up.
      Here are two screenshot of my problem :
      http://img716.imageshack.us/img716/6758/18651729.th.jpg
      http://img860.imageshack.us/img860/1432/81075928.th.jpg
      What can I do to keep these junction at 45 degrees ??
      Thank in advance.
        dsarchs
        Create the 4 corners and 4 sides each as separate groups. When you stretch it you only stretch the sides and the corners remain at 90 degree angles. Here is an old window example I made that does this (similar to what you're doing).
        milgard_window.skp
        Knowledge is a polite word for dead but not buried imagination.
        -e.e.cummings
        • K Offline
          karnalta
          I was thinking about this method, but I didn't know I will be able to hide the line, so I though my corner will have visible separation with the rest of my frame.
          I see on your example that they can be hidden and that is totally invisible, so I will that way too.
          Thank for your help.
