    Create a grid lines X by Y plugin
    4 Posts 4 Posters 452 Views 4 Watching
      jamma-pcb
      Hi all
      Does anyone know of a plugin that can slice up a face into square grid/ polygons.\
      Need to create a chess board kind of pattern but with alot more split square faces
      • sdmitchS Offline
        sdmitch
        Hatch_It
        http://forums.sketchucation.com/viewtopic.php?t=38637
        Divide by Material
        http://forums.sketchucation.com/viewtopic.php?t=37719
        If the face is square then the divisions will be square also. You will need to add a color/material to the face.
        http://sdmitch.blogspot.com/
        • jolranJ Offline
          jolran
          Hatchfaces will create edges you can explode on a face. I'm working on the next version, which hopefully will cope with this sort of thing. Pattern based tiling.
          Meanwhile you could also use Sdmitch component array 😉 and do some tiling with premade patterns there.
          • mitcorbM Offline
            mitcorb
            There is Grid2, by sepo, found in the Plugins Index, the red button at the top of this page. There is Grid at Ruby Library Depot, an excellent site, maintained by Didier Bur. Did not see one at Smustard.
