    Face between two arc curve
    3 Posts 3 Posters 1.4k Views 3 Watching
    • H
      hermannausowl
      I am looking for a way to create a face between two arc curve.
      ` model = Sketchup.active_model
      entities = model.entities
      group = entities.add_group
      entities = group.entities
      Halbkreis nach rechts / half curve to right
      center = Geom::Point3d.new 150.mm,0,0
      normal = Geom::Vector3d.new 0,0,1
      xaxis = Geom::Vector3d.new 1,0,0
      start_a = Math::PI/-2
      end_a = Math::PI/2
      edgearray = entities.add_arc center, xaxis, normal, 50.mm, start_a, end_a
      edge = edgearray[0]
      arccurve = edge.curve
      Halbkreis nach links / half curve to left
      center = Geom::Point3d.new 50.mm,0,0
      xaxis = Geom::Vector3d.new 0,1,0
      start_a = 0.0
      end_a = Math::PI
      edge = edgearray[0]
      face = entities.add_face arccurve
      status = face.pushpull 20.mm`
      Thank for help. ☀
      Wir planen Ihre Büroeinrichtung mit SketchUp. http://www.momo-moebel.de
      • TIGT
        Use arccurve1 and then arccurve2 for the two curves...
        then combine them
        face=entities.add_face(arccurve1+arccurve2)
        OR
        arccurve[0].find_faces
        BUT there's no automatic references to the new face
        although it is still get-able...
        • sdmitchS
          sdmitch
          hermann, The problem is that if you use edges or curves to add a face, they must form a closed figure which yours doesn't. What you need to do is extract and use the vertices of the two arcs to define the face. So after the first arc, add verts=arccurve.vertices. After the second arc, add verts+=arccurve.vertices. The add_face statement would then be face=entities.add_face verts.
          # Halbkreis nach rechts / half curve to right
          center = Geom;;Point3d.new 150.mm,0,0
          normal = Geom;;Vector3d.new 0,0,1
          xaxis = Geom;;Vector3d.new 1,0,0
          start_a = Math;;PI/-2
          end_a = Math;;PI/2
          edge = edgearray[0]
          verts = arccurve.vertices
          # Halbkreis nach links / half curve to left
          center = Geom;;Point3d.new 50.mm,0,0
          xaxis = Geom;;Vector3d.new 0,1,0
          start_a = 0.0
          end_a = Math;;PI
          edge = edgearray[0]
          verts += arccurve.vertices
          face = entities.add_face verts
          http://sdmitch.blogspot.com/
