    Paperbox - How to turn a 3d into a 2D pattern
    3 Posts 2 Posters 2.2k Views 2 Watching
      sheebom
      Hello,
      I have designed a box in 3d and I would like to make it in paper. For this I need to turn my 3D model into a 2D flat model which I can cut print, paste and assemble. Is there a way to do this automatically from the 3d model i designed on sketchup ? If not, do you know a programm that can do it ?
      Thank you for your answers.
      sheebom
      ps : herewith an exemple of a 3D model turned into what I call 2D flat to make it clear.
      • gillesG Offline
        gilles
        Try this:
        http://forums.sketchucation.com/viewtopic.php?t=27528#p238568
        there is also unfold.rb there:
        http://sketchuptips.blogspot.com/2007/08/plugin-unfoldrb.html
          sheebom
          Thank you. it sounds good, I will try these.
          Cheers,
          sheebom
