    Get form data from webdialogs?
    27 Posts 11 Posters 1.9k Views 11 Watching
      OK how about 'newline' ?
                $("select option;selected").each(function () {
                  str += $(this).text() + "\n";
      then in Ruby chosen=str.split("\n") ?
      Or even \r or \f ?
        That would be even more unlikely to appear, but it's still possible - for instance the Ruby API will allow \n. Who knows what an importer for instance might put in there when importing from some random data. Or if it takes input from somewhere without sanitising.
        I mean, it's unlikely, but still possible. Where as using an escape character scheme would make it 100% safe. And it's a simple thing as well.
        <span class="syntaxdefault">def escape_pipe</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> string </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'\\'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'\\\\'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'|'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'\\|'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /><br />def restore_pipe</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> string </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'\\\\'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'\\'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'\\|'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'|'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
          bigcatln
          so far there is no elegant solution for it!
          Javascript may be useful but have problem when handling mutibyte characters
            Eh? Javascript is unicode compatible... Ruby on the other hand, the 1.8 branch we're stuck with in SU, only deal with strings as ASCII characters.
              bigcatln
              The problem is JSON doen't support Multibyte characters in fact. when you restore Json str from javascript in ruby,it can't be handled correctly
                But that's a problem with Ruby 1.8 which only handle ASCII strings - and not a problem with JavaScript...
                • P Offline
                  Pout
                  I always do as chris does:
                  collect in one string, send to SU, split there if needed
                  • 2 / 2
