    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 57.1k Views 16 Watching
    • thomthomT
      Current WIP
      https://bitbucket.org/thomthom/sketchup-ruby-c-extension
      Working OSX and Windows "Hello World" example.
      This question comes up from time to time, how to compile a Ruby C Extension that works for SketchUp.
      Following tutorials for standard Ruby will not work for SketchUp without modifications. It would be nice if we could properly document this.
      For OSX I think I have all the info, thanks to AdamB that explained that it needed to be compiled into a flat namespace: http://forums.sketchucation.com/viewtopic.php?f=180&t=28673&start=0#p249370
      However, would be nice if anyone knew how to generate a make file with the correct flags so one does not have to edit it manually every time - like I do... πŸ˜• 😳 )
      For Windows it's even more to be done. TBD helped me out here with his Pelles C project. However, I was unable to create and set up a project for compilation myself and I have no idea what is needed to make it compile correctly. I'd like to learn this.
      One thing is that the C Extension under windows requires you to install a standard ruby installation and modify config.h to bypass a MSC check. (Or does anyone have a solution that doesn't require this?)
      I see Dana is using a make file that seem to be used on both platforms: https://github.com/danawoodman/google-sketchup-file-downloader/blob/master/src/CMakeLists.txt
      However, that project doesn't work in SketchUp yet.
      So, the short story is, can we (the devs here) put together a step by step tutorial on how to compile a SketchUp Ruby C Extension for OSX and Windows?
      (I can write it up, but I need someone to provide with the technical and explains how and why.)
      • tbdT
        tbd
        can you fork https://github.com/TBD/OpenSUP/tree/master/SUExt and send a pull request for the OSX version ?
        will try to make a step by step page for compiling on PellesC (I will not install VStudio on virtual machine πŸ˜‰
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
        • thomthomT
          There is an OSX version? I'm not sure what you mean about sending a pull request... 😳
          What would be nice is along with the tutorial we could set up the framework for making and compiling on both platforms with minimum mount of per-platform files. If possible?
          • thomthomT
            I clicked Fork when I was under SUExt - and it forked the whole repository. I guess there is no way to fork a part of a repository... ?
            • thomthomT
              Clicking "Pull Request" and I get a message:
              "Oops! The TBD:master branch is already up-to-date with thomthom:master β€” maybe you want to try something else?"
              ....I should stop clicking now... 😳
              • tbdT
                tbd
                fork - it creates a duplicate of the entire project in your account. you can change only in one subdirectory if you want.
                pull request - you make the changes in your forked project and send a pull request so I can integrate your changes
                you need to add some changes to send a pull request to me first.
                http://plugins.ro
                • thomthomT
                  Right. Should I leave the other folders alone?
                  Just thinking it might be nice with a repo just for C Extension - nothing else. Just to keep it clean and simple. ❓
                  • tbdT
                    tbd
                    https://github.com/sketchucation is ready to accept projects πŸ˜‰
                    http://plugins.ro
                    • thomthomT
                      Right'o. So can we create an "SketchUp Ruby C Extension" project? Then start adding stuff.
                      • tbdT
                        tbd
                        pull requests away - https://github.com/sketchucation/suext πŸ˜‰
                        http://plugins.ro
                        • thomthomT
                          I just got a very simple Hello World example working under OSX. Will create another example with some basic Ruby object interactions and expand a little on my comments. Then I will upload it to a repository. Think I'll focus on the step by step for OSX first to get the structure up. Then Windows - seem to be a bit more tweaking to get that working.
                          • Chris FullmerC
                            This sounds great Thom and TBD and everyone one else who gets involved. I keep being afraid that I might need to learn some of this for my upcoming work.
                            Chris
                            All my Plugins I've written
                            • thomthomT
                              What you got cooking?
                              • thomthomT
                                Right - attempting to build on Windows.
                                I have Visual C++ Express 201 installed and I'm trying to build using nmake. Getting some errors:
                                I'm not sure what that means. Though I have a suspicion I need to specify the path to where windows.h is located... Though I don't know where to do so...
                                • thomthomT
                                  Uploaded my WIP at: https://bitbucket.org/thomthom/sketchup-ruby-c-extension/
                                  Working on OSX 10.5.
                                  • thomthomT
                                    Note for self: http://blogs.law.harvard.edu/hoanga/2006/12/14/getting-a-ruby-c-extension-to-compile-on-windows/
                                    • thomthomT
                                      Think I got one step further. This thread mentions that vcvars32.bat needs to be run from the prompt: http://social.msdn.microsoft.com/Forums/en-US/Vsexpressvc/thread/325b5459-c469-40d0-bf6d-e3356a2f14cd/
                                      And this (http://stackoverflow.com/questions/6622869/problem-with-nmake)
                                      So after I did that I got a different error. Missing crt file...
                                      • thomthomT
                                        ( Apologies for those with the know-how - I will be posting lots of silly stuff as I work through this. Posting to make a record of what I am doing. "Thinking out loud". )
                                        • thomthomT
                                          Got it working!
                                          Uncommented a #pragma comment(lib, "crt.lib"); I had. TBD's SUExt project had a reference to it. Which is what I based my project on. Seeing how it also referred to #pragma comment(lib, "msvcrt-ruby18.lib"); I just tried to see what happened if I removed the ref to crt.lib. Everything worked fine after that point.
                                          Now I wonder what the other lines do:
                                          #pragma comment(lib, "kernel32.lib") #pragma comment(lib, "gdi32.lib") #pragma comment(lib, "user32.lib") #pragma comment(lib, "shell32.lib")
                                          I'm looking at this tutorial: http://blogs.law.harvard.edu/hoanga/2006/12/14/getting-a-ruby-c-extension-to-compile-on-windows/
                                          It made no reference to any of this. ( what is it? Is it really required? )
                                          I'm guessing #include <windows.h> is required though.
                                          • thomthomT
                                            Now... I'd like to find a way to make any output from extconf.rb and make/nmake put everything is a separate directory - for each platform.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 4 / 9
