    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 39.0k Views 16 Watching
      send a pull request for the OSX version ?
      There is an OSX version? I'm not sure what you mean about sending a pull request... 😳
      What would be nice is along with the tutorial we could set up the framework for making and compiling on both platforms with minimum mount of per-platform files. If possible?
        I clicked Fork when I was under SUExt - and it forked the whole repository. I guess there is no way to fork a part of a repository... ?
          Clicking "Pull Request" and I get a message:
          "Oops! The TBD:master branch is already up-to-date with thomthom:master β€” maybe you want to try something else?"
          ....I should stop clicking now... 😳
          • tbdT Offline
            tbd
            fork - it creates a duplicate of the entire project in your account. you can change only in one subdirectory if you want.
            pull request - you make the changes in your forked project and send a pull request so I can integrate your changes
            you need to add some changes to send a pull request to me first.
            http://plugins.ro
              Right. Should I leave the other folders alone?
              Just thinking it might be nice with a repo just for C Extension - nothing else. Just to keep it clean and simple. ❓
              • tbdT Offline
                tbd
                https://github.com/sketchucation is ready to accept projects πŸ˜‰
                http://plugins.ro
                  Right'o. So can we create an "SketchUp Ruby C Extension" project? Then start adding stuff.
                  • tbdT Offline
                    tbd
                    pull requests away - https://github.com/sketchucation/suext πŸ˜‰
                    http://plugins.ro
                      I just got a very simple Hello World example working under OSX. Will create another example with some basic Ruby object interactions and expand a little on my comments. Then I will upload it to a repository. Think I'll focus on the step by step for OSX first to get the structure up. Then Windows - seem to be a bit more tweaking to get that working.
                      • Chris FullmerC Offline
                        This sounds great Thom and TBD and everyone one else who gets involved. I keep being afraid that I might need to learn some of this for my upcoming work.
                          What you got cooking?
                            Right - attempting to build on Windows.
                            I have Visual C++ Express 201 installed and I'm trying to build using nmake. Getting some errors:
                            I'm not sure what that means. Though I have a suspicion I need to specify the path to where windows.h is located... Though I don't know where to do so...
                              Uploaded my WIP at: https://bitbucket.org/thomthom/sketchup-ruby-c-extension/
                              Working on OSX 10.5.
                                Note for self: http://blogs.law.harvard.edu/hoanga/2006/12/14/getting-a-ruby-c-extension-to-compile-on-windows/
                                  Think I got one step further. This thread mentions that vcvars32.bat needs to be run from the prompt: http://social.msdn.microsoft.com/Forums/en-US/Vsexpressvc/thread/325b5459-c469-40d0-bf6d-e3356a2f14cd/
                                  And this (http://stackoverflow.com/questions/6622869/problem-with-nmake)
                                  So after I did that I got a different error. Missing crt file...
                                    ( Apologies for those with the know-how - I will be posting lots of silly stuff as I work through this. Posting to make a record of what I am doing. "Thinking out loud". )
                                      Got it working!
                                      Uncommented a #pragma comment(lib, "crt.lib"); I had. TBD's SUExt project had a reference to it. Which is what I based my project on. Seeing how it also referred to #pragma comment(lib, "msvcrt-ruby18.lib"); I just tried to see what happened if I removed the ref to crt.lib. Everything worked fine after that point.
                                      Now I wonder what the other lines do:
                                      #pragma comment(lib, "kernel32.lib") #pragma comment(lib, "gdi32.lib") #pragma comment(lib, "user32.lib") #pragma comment(lib, "shell32.lib")
                                      I'm looking at this tutorial: http://blogs.law.harvard.edu/hoanga/2006/12/14/getting-a-ruby-c-extension-to-compile-on-windows/
                                      It made no reference to any of this. ( what is it? Is it really required? )
                                      I'm guessing #include <windows.h> is required though.
                                        Now... I'd like to find a way to make any output from extconf.rb and make/nmake put everything is a separate directory - for each platform.
                                          Huh... I removed all of that stuff completely, as http://blogs.law.harvard.edu/hoanga/2006/12/14/getting-a-ruby-c-extension-to-compile-on-windows/ made no reference to it at all. Worked fine without. Guess it was required due to the way the Pelles C project was set up... ❓
                                            Hey Chris, when we get around to writing up the step by step instructions, are you willing to be a guinea pig?
                                            • 1 / 9
