    [C\C++] SketchUp window handle
    12 Posts 3 Posters 1.4k Views 3 Watching
    • T
      tomasz
      What is the most reliable and safe way to get SketchUp main window handle?
      1. Finding a "main" application of my .dll,.dlib?
      2. Guessing a name of SU Window and then figuring out the window handle (I have seen it in WxSU, but it was unreliable)?
      3. Creating a WebDialog with an unique name, finding it and getting its' parent?
        4...
      Will a procedure be much different on MAC?
      • thomthomT
        I'm doing this: http://www.thomthom.net/software/sketchup/tt_lib2/doc/TT/Win32.html#get_sketchup_window-class_method
        <span class="syntaxdefault"><br />def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_sketchup_window<br />  hwnd </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> GetActiveWindow</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call<br />  return nil if hwnd&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">0<br />  </span><span class="syntaxcomment"># In case the SketchUp window was not the active one - get the ancestor.<br /></span><span class="syntaxdefault">  GetAncestor</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">call</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">hwnd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> GA_ROOTOWNER</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
        Guessing the name of the Window - what if you have multiple windows, or your browser has an article of SketchUp open?
        I used GetActiveWindow because it returns a window for the current process. Then I get the ancestor because that will be the SketchUp window. However, it only work if SketchUp or any of its child windows has focus. If the function is called when another application has focus you get nil.
        Maybe it can be obtained from the process id?
        I'd like to know how to do this. The method above is using the Win32 API - and no Googling has lead me to any solution for OSX. 😞
        • thomthomT
          Here's a stack overflow thread I made earlier trying to work out how to get the window handle: http://stackoverflow.com/questions/4548354/win32-can-one-enumerate-the-windows-belonging-to-the-calling-thread
          I've not implemented it yet though.
          • Dan RathbunD
            Dan Rathbun
            a note that on the C side of things, the constant NULL is set to the integer 0, which is what C will return for many Win API functions that are unsuccessful.
            Win32API.so I don't think converts a C NULL into a Ruby nil
            I'm not here much anymore.
            • thomthomT
              You're right. That was a wee bug in my code there. I compare against 0 elsewhere. Thanks for spotting that.
              • T
                tomasz
                I have succeeded to find SU hwnd in a following way (pseudo-Ruby \ C++ code):
                		curr_proc_id = GetCurrentProcessId();
                		h = GetTopWindow(0);
                		while ( h )
                				 pid=GetWindowThreadProcessId( h );
                				 if ( pid == curr_proc_id )
                					class_name=GetClassName( h );
                					if (class_name[0..2]=='Afx' && class_name[13]=='b') su_hwnd=h;
                				h = GetNextWindow( h );
                		return su_hwnd;
                p.s. I am a spoiled child. I want my Ruby back!!! 🎉 I hate defining almost every single byte in memory!
                Mac OSX now...
                • Dan RathbunD
                  Dan Rathbun
                  The current pid in Ruby is the global $$, or a call to: Process.pid()
                  • thomthomT
                    GetTopWindow(0)
                    What does this actually do?
                    • T
                      tomasz
                      @thomthom said:
                      GetTopWindow(0)
                      It gets "top most" window.
                      If this parameter is NULL (0), the function returns a handle to the window at the top of the Z order.
                      The z-order of a window indicates the window's position in a stack of overlapping windows. This window stack is oriented along an imaginary axis, the z-axis, extending outward from the screen. The window at the top of the z-order overlaps all other windows. The window at the bottom of the z-order is overlapped by all other windows.
                      http://msdn.microsoft.com/en-us/library/windows/desktop/ms633514(v=vs.85).aspx
                      GetNextWindow
                      gets a window beneath.. till all windows examined.
                      • thomthomT
                        How fast is it to search through all the windows and do string comparison?
                        • T
                          tomasz
                          I haven't learned yet how to measure time in C (whole function is written in C), but I guess it is very fast. 😄
                          • thomthomT
                            Here's a way that doesn't iterate every windows there is. It enumerates the windows of the calling thread. Cuts down the searching and ensure that you don't get the wrong window.
                            win32_sketchup_window.rb
