    Sketchup to pepakura problems
    7 Posts 3 Posters 710 Views 3 Watching
    • L
      Lalala
      I am having trouble using sketchup 8 with the shareware program pepakura, which allows you to unfold a 3d model into paper templates to make it in paper craft. The problem I have is that when I open the sketchup file in pepakura, it works fine, but some of the faces of what I have made are not joined so it will not unfold properly. When I go into sketchup, there is no way that I can find to join these faces. My models are fairly complicated and are not just boxes or simple shapes, so what I wanted to know was does anybody know how to make all the faces joined in pepakura.
      Thanks in advance.
      • C
        chango70
        Thanks in advance.
        Have you tried using 3DS files or Objs? They work better with Pepakura in my limited experience with the program.
        • TIGT
          Are your exported objects manifold solids beforehand ?
          If not then use one of the available tools to fix them...
          • L
            Lalala
            Im very sorry but i have absolutely no idea what any of thet means I only have a very limited experience, if it's not too much to ask could someone please explain that in lay mans terms for me. Also I only have the free version of sketchup so I can only export in skp and collada.
            Thanks in advance.
            • TIGT
              If you select a group or component-instance and then use Entity Info it returns some details in a dialog. If it has the word 'Solid' in its title then it's a 'manifold-solid' - like a simple 3d 'box'.
              If it doesn't have that word in its title then it's not a 'solid' - it has holes, internal partitions or 'flaps' that don't meet other faces etc...
              Manifold solids unfold relatively easily, because every edge has two faces - no more, no less.
              Other non-manifold forms will often have problems as they will have an edge can have more or fewer faces that it must try to unfold...
              • L
                Lalala
                tankyou. that made perfect sense and i have checked some of my models and found that they are not manifold solids. what were these tools you were mentioning that can fix them and where could i get them.
                thanks in advance.
                • L
                  Lalala
                  forget my last post i just found that when something is a group it counts as a solid but when the same object is not grouped it is an entity. what does this mean?
