    Error: undefined method '+' for nil:NilClass
    3 Posts 2 Posters 3.4k Views 2 Watching
    • K
      klaufi
      Hi there
      I got a new notebook and now SU8 is finally working. I wanted to script something in Sp3, but it didn't work right. There was an error message, which told me "undefined method 'atan2' for nil:NilClass". So I made a simple testing program and even that didn't work. Here's the code:
      if frame==0
         $a=1
         $b=2
      $c=$a+$b
      puts "1+2=#{$c}"
      it should just handle some variables and send the result to the ruby-console, but by hitting play I always got this error message:
      "undefined method '+' for nil:NilClass"
      Even if I used local variables, it didn't change anything. By using getVar and setVar it worked, but the result was always 0.00
      What's going wrong?
      • TIGT
        Don't use $ global variables.
        There is rarely a reason that can't be side stepped - use a, b and c.
        If frame is not 0 then a or b are not set to anything, so the error is correct because nil + nil doesn't work !
        • K
          klaufi
          Ok, now this works.
          Now I have another problem: I can't read out the frame in the scripted box.
          if i do so, an error message appears.
          When I write something like
          Math.sin(frame/100.00)
          in the controller of a servo, it works, but if I write
          setVar("a",frame/100.00)
          and into the controller
          getVar("a")
          the error message occurs.
          That's really odd...
          edit: It seems, that my old SP models work well, but if I copy the code into a new Scripted-box ob an object, it doesn't work anymore. Maybe I should get an older Version of SP?
