    DCs stops working in large models?!
    3 Posts 2 Posters 483 Views 2 Watching
      Marron
      Hi!
      We have some dynamic components when we make layouts for production plants.
      But when the models becomes large with a lot of items they stops working as intended.
      I attach one of these DCs. The problem with this one is that the door doesn't change size ("Dörrbredd" and "Höjd" is it called in the component).
      Our components just changes dimensions, we don't use any interaction.
      Is there more of you who have run into similar problems?
      Thanks in advance!
      Staketdörr_dynamiskt_v1108.skp
      • AnssiA Offline
        Anssi
        I think that your problem is that your subcomponents are trying to reference parameters from their siblings. I understand that parameters can be passed only between grandparent, parent and child. In this case I think the culprit is that the Startstolpe and Endstolpe components are trying to read values from the Panel component.
        Anssi
          Marron
          Anssi
          Thanks, will look in to that! 😃
