    Using the Follow-Me tool?
    2 Posts 2 Posters 229 Views 2 Watching
      bob-designer
      Trying to extrude the profile attached to the edge of the plate component supplied on the attached file. Using Follow-Me, the extruded profile does not follow around the corners. Where am I going wrong? Your sugestions please.
      Thank you for your help, Bob
      PLATE-19.skp
      • BoxB Offline
        It looks to be just that everything is a bit too small. SU has problems creating small or really big faces. I scaled it all up by a factor of 10 and it works fine, you can scale down afterwards and the faces will remain.
