    I need your help
    5 Posts 4 Posters 337 Views 4 Watching
    • H Offline
      hanthu250688
      Hello everybody,my english isn't well,but i want to cover plane by net likes under picture,i don't know using any plugin,thank all.
        steve2802
        Hi Hanthu,
        If I understand correctly you wish to create a mesh or net.
        Have you tried the sandbox tools?
        Window / Preferences / Extensions - Check "x" the sandbox tools.
        Then.
        View / Toolbars / Sandbox.
        You can then use your plane or contours to make a mesh. Double click the mesh and you can "add detail" using sandbox tools.
        Hope this helps.
        • H Offline
          hanthu250688
          thank steve 2802,but i want to create the airmchair like the picture i showed,i want to edit the object into the mesh object like picture,oh,my english is not well to destribe correct
          • mitcorbM Offline
            mitcorb
            Hi, hanthu..
            Did you make the model in the image? Or do you wish to make the model in the image? Because, here is my interpretation:
            View> Hidden Geometry to see the mesh?.
            or view in Wireframe Mode. I am thinking you may want the mesh without faces?
            • ely862meE Offline
              ely862me
              I actually think that you need to get to know SDS aka Artisan : http://forums.sketchucation.com/viewtopic.php?f=323&t=34868&hilit=artisan .
              Also for a extruding the edge you can use JPP joint push pull : http://forums.sketchucation.com/viewtopic.php?t=6708.
              Now depends on how your imagination works.
              Cheers!
              Elisei (sketchupper)
              Come and See EliseiDesign
