    [Request]is there have a plugin can do like this?
    7 Posts 3 Posters 416 Views 3 Watching
    • G Offline
      gavvy
      or the ways to do dis quickly?
      The third is the result i want.
      😐 thanks.
      • jolranJ Offline
        jolran
        Hm maybe not exactly. I'll give you a somewhat biased tip πŸ˜‰ .
        You can get crossed lines with angle options in current version of Hatchfaces.
        Maybe if you try a grid like pattern (cross 90 deg) and a second crosshatching maybe 30 deg.? You'll end up with pic 1.
        Do you have a style on? The Vertical middle-edge looks thicker on pic 3.
        Next version of Hatchfaces will have some more options that could do this kind of thing(pattern style). It's in it's works..
        • TIGT Online
          Look under the Plugins Index for 'Latticeizer'.
          It works on a grouped set of coplanar faces/edges.
          To make the inset edges apply a half-frame sized offset before dividing, otherwise the outermost frame is centered on the perimeter edges too...
          • jolranJ Offline
            jolran
            Or is it Lattice Maker v1.2 (TIG) ?
            There sure are many plugins to keep track of. Must admit, havent tried them all.
            This one looks really interresting though, even if it isen't the one TIG mentioned first.
            • TIGT Online
              My newer 'LatticeMaker' will work too - especially on 3d meshes [e.g. curved roofs], but my simpler/earlier 'Latticeizer' was specifically written for 2d flat coplanar faces groups [e.g. windows]...
              • G Offline
                gavvy
                β˜€ Thanks. Waitting TIG's newner script 😍
                • TIGT Online
                  It's 'newer' NOT 'new'!
                  It's been around for a while...
                  Look for it in the 'Plugins Index' lists...
                  'LatticeMaker' works on premade meshes - it has a sibling in the Extrusion Tools tool 'EEbyRailsToLattice' that takes curves and makes the 'mesh-grid', and if option is selected it also frames/panes it...
