    Square to round transition
    3 Posts 3 Posters 1.7k Views 3 Watching
      dr3d
      Hello,
      In my work I have to draw very often this kind of transition and there is never one of such. even if it does not take me much time,
      I would like to create a dynamic component that looks like this:
      http://imageshack.us/f/35/screenaj.jpg/
      the idea is to "parameter" the different lengths that I listed and perhaps the number of segments for the circle.
      When I tried to create the block, I was not able to connect the edges of the round and rectangular, but it's something easy to do "manually" with the tools SU
      in your opinion should I separate the block into 3 parts 'round part', part rectangular, part transition?
      there is a function for change the size of a face? like a "dynamic" cylinder that could turn into a cone?
      This is at least possible to do this kind of block? ^ ^
      thank you
      Laurent
        mwm5053
        Fredo6's curviloft plug in would be pretty easy
        http://forums.sketchucation.com/viewtopic.php?t=28586
        you could then push-pull the ends to make them a flange of sorts.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • Jean LemireJ Offline
          Jean Lemire
          Hi folks.
          See this SU file for ideas.
          Square to round transition.skp
          Once this model is done, it can be used as a component and quickly resized to required dimensions using the Scale Tool.
          Of course, a dynamic component would probably save a few clicks.
          Just ideas.
