    Close model
    6 Posts 3 Posters 465 Views 3 Watching
    • H Offline
      hermannausowl
      It is possible to save the current model to a file. It is possible to
      open a new model from a file. I can't see a way to close the current
      model.
      Wir planen Ihre Büroeinrichtung mit SketchUp. http://www.momo-moebel.de
        http://code.google.com/apis/sketchup/docs/ourdoc/model.html#save
        http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#open_file
        You can't use the current model's name in a save, as that gives an error as it's in use - but you can save it as a temp-name then delete the original SKP [File.delete() etc] then do another save with the original name and erase the temp file... That way it's like you saved the file from the File menu...
        See my Archiver tool that does this kind of thing - it has to save the current SKP as something else then open the original in a twinkling of an eye...
        • Dan RathbunD Offline
          Dan Rathbun
          Sketchup.open_file()
          I'm not here much anymore.
          • H Offline
            hermannausowl
            Thanks for help, this is the result:
            def zeichnung_starten()
                model = Sketchup.active_model
                require "ftools"
                prompts  = ["neue Planung starten        ","neuer Dateiname"]
                defaults = ["Raum","Test"]
                list     = ["Raum|Tische|Schraenke|Standard"]
                input = UI.inputbox prompts, defaults, list, "Planung neu"
                datei = input[0]
                datei_neu = input[1].to_s
                directory = "/Library/Application\ Support/Google\ SketchUp\ 8/SketchUp/plugins/mo_mo_moebel/Vorlagen"
                weg = directory + "/"+ datei + ".skp"
                neu = "/Users/Benutzer/Planungen\ aktuell/" + datei_neu + ".skp"
                File.copy(weg, neu)
                result = Sketchup.open_file neu
              Dan Rathbun
              your directory ref is OSX only. It's different on PC.
              use this for lines 11..13:
              ` subdir = 'mo_mo_moebel/Vorlagen'
              plugdir = File.expand_path( Sketchup.find_support_file('plugins') )
              weg = File.join( plugdir, subdir, "#{datei.to_s}.skp" )
              usrdir =( RUBY_PLATFORM =~ /(darwin)/ ? ENV['HOME'] : ENV['USERPROFILE'] )
              usrdir = File.expand_path( usrdir )
              neu = File.join( usrdir, 'Planungen aktuell', "#{datei_neu}.skp" )`
              • H Offline
                hermannausowl
                There is an error "stack level to deep" after line "File.copy(...)".
                Who can help me?
