    Dynamic component, Ruby and MySQL
    2 Posts 2 Posters 572 Views 2 Watching
    • B
      blue_orchid
      [color=#BF4040]UI.menu("Plugins").add_item('Condition Rating1') { Jeny.paint }
      module Jeny
      def self.paint
      require 'mysql'
      dbh = Mysql.real_connect("localhost", "root", "***", "test",3306)
      dbh.query("drop table if exists condition_rating")
      dbh.query("create table condition_rating(component varchar(20), rating int(1))")
      dbh.query("insert into condition_rating values('Deck',1),('Superstructure',2), ('Substructure',3)")
      #printf "%d rows were inserted\n",dbh.affected_rows
      res = dbh.query("SELECT * FROM condition_rating where rating = '3'")
      while row = res.fetch_row do
      #dbh.query("SELECT * FROM condition_rating")
      #printf "%s, %s\n", row[0], row[1]
      a=row[0]
      b=row[1]
      printf "%s, %s\n",row[0],b
              Sketchup.active_model.entities.to_a.each{|e|
                  if b=='1'
                      e.definition.set_attribute 'dynamic_attributes', 'material', 'red'
                      e.definition.set_attribute 'dynamic_attributes', '_material_formula', '"red"'
                      $dc_observers.get_latest_class.redraw_with_undo(e)
                  elsif b=='2'
                      e.definition.set_attribute 'dynamic_attributes', 'material', 'green'
                      e.definition.set_attribute 'dynamic_attributes', '_material_formula', '"green"'
                  elsif b=='3'
                      e.definition.set_attribute 'dynamic_attributes', 'material', 'blue'
                      e.definition.set_attribute 'dynamic_attributes', '_material_formula', '"blue"'
                 elsif b=='4'
                      e.definition.set_attribute 'dynamic_attributes', 'material', 'yellow'
                      e.definition.set_attribute 'dynamic_attributes', '_material_formula', '"yellow"'
                 elsif b==5
                      e.definition.set_attribute 'dynamic_attributes', 'material', 'cyan'
                      e.definition.set_attribute 'dynamic_attributes', '_material_formula', '"cyan"'
                 elsif b==6
                      e.definition.set_attribute 'dynamic_attributes', 'material', 'darkorange'
                      e.definition.set_attribute 'dynamic_attributes', '_material_formula', '"darkorange"'
                 elsif b==7
                      e.definition.set_attribute 'dynamic_attributes', 'material', 'lightgreen'
                      e.definition.set_attribute 'dynamic_attributes', '_material_formula', '"lightgreen"'
      end[/color]
      What I did in the script
      1. created the MySQl table and its data using ruby script
      Table contains these two columns which are Component and Rating
      Values of table:
      a.Component:Deck, Rating: 1
      b.Component: Superstructure, Rating:2
      c.Component: Substructure, Rating:3
      I created the ruby saying that if rating is 1, then color that object.
      GoogleSketchup:
      I created model which have dynamic components like deck, superstructure and substructure with an attribute 'rating'. This attribute for each component has values from 1-7.
      My problem: I am unable to connect the dynamic components of sketchup model to the 'component' of MySQL table.
      • TIGT
        This is only going to be accessible to those user who have require 'mysql' accessible...
        Can you be a little more generic in your question ? πŸ˜•
        OR perhaps more specific... and change the post's title to say
        ' MySQL, Ruby and Dynamic-Components - HELP!'
