    Kerkythea - SketchUp 8 Help
    extensions
    3 Posts 3 Posters 691 Views 3 Watching
    • K Offline
      kilc6887
      Hello,
      I need some help with an issue. I created a model in SketchUp 8 and somehow I've lost track of that model. I spent quite a bit of time on it so I'd like to get it back if I can. Its been a few months since I created it and I've searched every where for it. I still have the 3D Kerkythea model that I exported from SketchUp. Is there a way I can take that 3D model from Kerkythea to SketchUp? Will SketchUp Pro import Kerkythea files? I'd appreciate any help here as I'm in a pinch.
      Jake
      • FrederikF Offline
        Frederik
        That's sad to hear, but I'm afraid you're a little lost here...
        There's a small app (KT2OBJ), which might help you... 😐
        Cheers
        Kim Frederik
        • N Offline
          notareal
          Like said, KT2OBJ is the pretty much the only way to export from KT to SU. http://web.axelero.hu/karpo/ might also work, but some years ago it did fairly poor job.
