Tips about running more than one Sketchup
6 tips for a better sketchup
Load sketchup in 2 sec, with no plugin loaded
Clean up skutchup Reg.
Load SketchUp8.reg to Wordpad.
Delete all ToolbarsUser-Bar informtion and also the ToolbarsUserCustom-Bar too. (may be a 1000) then save as sys clear.regEasy to load plug-ins.
Unlimited plug-in loads.
Load plug-in only when you need them.(This is my best tip all year of 2011)
When sketchup starts it doesn't see any hidden ruby files, you can hide what you don't need to load yet,
and load the require ones that you do.
Later with a ruby toolbar script loader you can load the hidden ones you want. That's because your telling about the name, type and location of ea. plug-ins... thus no double buffering of plug-in folders and also the plug-ins are in the folder that are meant to be in.Loads all plugins in normal plugin file.
Low ram usage on startup.
Easy to load Ruby toolbar
This perhaps is the only loader you need.
Easy to do.
Making a repeatable script loader ( use cancel to stop).
Easy to edit.
Just add rt_load
Fix most gray outs.
When you need to start an .rbs, unhide it and start a 2rd SU.
tip2 There are some copy programs that can copy many levels of copys with sketchup (25 level+) M8 Free Multi Clipboard: Free Clip
clip on_clip off
This make a good way to caddy tranfer objects to another sketchup.
So if you 5 trees 5 plants and 5 rocks it be eazy to arrage into a scene in another sketchup. -
- tips
Some Sketchup noted Hints: by dukejazz in the making of Another Sketchup Plus Ver. 1.2
1 To manually (flush a clipboard) 3d entities clean: Use 3d text tool and copy a leter of text Then [cancel] out.
2 Another Sketchup (auto clear clipboard) uses a Cmd.link script to clear clipboard. A ruby API script that could do this, was not found.?
3 (Security reasons): Flush clipboard when you leave your work area.
4 (Never loose a documents) Make use of making copies of your document in your brower.
5 (Smart) Open brower's copies to rework on keeps you saving back to original.
6 (Limits gray-out) Keep startup and console loaded plug-ins to small and few.
7 (Keeps Skp file size small) In model, components and materials: uses (Via) Save and purge.
8 (Watch memory flow:) Task manager: It is normal for parents overhead memory to be larger than a child.
9 (Large doc gray-outs) Open a new parent copy of the document to paste back into it, because of larger overhead of note 8.
10 (Max File save size) Max file size is by power of zoom extents, and by zoom in/out decreases the save size?
11 (Polyreduce if you can) Overworking objects gives higher code counts.
12 (Bug splats)HKEY_CURRENT_USER\Software\Google\SketchUp8.
a (Find) ToolbarsUser-Summary and ToolbarsUserCustom-Summary.
b (via) Right-click_ permission special _ to you full control on and you read off. The resticted and system read only_full control is off . This (Locks) Toolbars to fix num ToolbarsUser_limits overloading your registers.
13 By using a Sketchup::require statement, in a rb, loads a rbs scrip to console.
14 Fix you startup rbs code to zero by via note 8. Another Sketchup Plus Ver. 1.2 runs as ruby script with extensions. - tips
Register LoginAdvertisement
