    Tips about running more than one Sketchup
    23 Posts 10 Posters 10.2k Views 10 Watching
    • GaieusG
      i use β‡§βŒ˜V
      Is that Greek for Shift+Ctrl+V? πŸ˜† (that's what I use actually)
      • jeff hammondJ
        @gaieus said:
        i use β‡§βŒ˜V
        yes, i do in fact have a greek keyboard! how'd you know?
        πŸ˜†
        • GaieusG
          Well, I did not really mean "Greek" but just the saying when something is "Greek to me". We (in Hungary) actually say "it's Chinese to me" but these proverbs have different variations.
          "A hungry horse dreams of oats" would sound like "a hungry pig dreams of acorns" in Hungarian (well, would not really soundlike this as I translated it...)
          • jeff hammondJ
            nah.. i know that saying too (and i also use the chinese version more often than the greek)..
            i was just making a joke out of it..
            • GaieusG
              Ah, one never knows... πŸ˜†
              • irwanwrI
                irwanwr
                @broomstick said:
                My tip would be: different versions save your life!
                Keeping Sketchup 7 free at hand means you can import dwg files, and then open everything in Sketchup 8 free to do all the work!
                πŸ˜‰
                πŸ‘
                that is interesting. i think i need to search for SketchUp 7 to download.
                • dukejazzD
                  dukejazz
                  [plugin] Another_Sketchup 1.0
                  Works in Sketchup 6,7,or 8
                  It works in the context menu named " - Another Sketchup ".
                  Just give a right click on any object for automation of loading a another sketchup.
                  Its helps to rework any docucments objects.
                  When done reworking then paste in place back to your docucment.
                  It have the following submenus: - note
                  1 Copy selected to another Sketchup. -rework object
                  2 Move selected to another Sketchup. -rework object
                  3 Paste in place to another sketchup. -rework object
                  4 Copy all to another sketchup. -restart unhidden plugins
                  5 Copy all and Exit your Sketchup. - Please place in place back after it closes to any of the open sketchup or start a skp file to auto paste in place. If it paste in place to your new sketchup and you dont need it just hit undo. Warning the copy is lost if you clip to clipboard before you paste in place.
                  [plugin] Another_Sketchup_Plus v1.2 is now a toolbar
                  • dukejazzD
                    dukejazz
                    Lower plugin memory usage, mean bigger skp graph files. Yes?
                    • dukejazzD
                      dukejazz
                      Your guys are right!
                      My tips 2 should read
                      Tip 2) Cut and paste or paste in place
                      a) You can cut and past between between same levels of sketchup programs. 8-8 7-7 6-6
                      b) There are some copy programs that can copy many levels of copys with sketchup (25 level+ or more) M8 Free Multi Clipboard: Free Clip, Spartan Trial Upgrade
                      Spartan can store, name, and save hundreds of small pasteable objects
                      • dukejazzD
                        dukejazz
                        6 tips for a better sketchup
                        Load sketchup in 2 sec, with no plugin loaded
                        Clean up skutchup Reg.
                        Load SketchUp8.reg to Wordpad.
                        Delete all ToolbarsUser-Bar informtion and also the ToolbarsUserCustom-Bar too. (may be a 1000) then save as sys clear.reg
                        Easy to load plug-ins.
                        Unlimited plug-in loads.
                        Load plug-in only when you need them.
                        (This is my best tip all year of 2011)
                        When sketchup starts it doesn't see any hidden ruby files, you can hide what you don't need to load yet,
                        and load the require ones that you do.
                        Later with a ruby toolbar script loader you can load the hidden ones you want. That's because your telling about the name, type and location of ea. plug-ins... thus no double buffering of plug-in folders and also the plug-ins are in the folder that are meant to be in.
                        Loads all plugins in normal plugin file.
                        Low ram usage on startup.
                        Easy to load Ruby toolbar
                        This perhaps is the only loader you need.
                        Easy to do.
                        Making a repeatable script loader ( use cancel to stop).
                        Easy to edit.
                        Just add rt_load
                        Fix most gray outs.
                        When you need to start an .rbs, unhide it and start a 2rd SU.
                        • dukejazzD
                          dukejazz
                          tip2 There are some copy programs that can copy many levels of copys with sketchup (25 level+) M8 Free Multi Clipboard: Free Clippic_0001.jpg
                          clip on_clip off
                          This make a good way to caddy tranfer objects to another sketchup.
                          So if you 5 trees 5 plants and 5 rocks it be eazy to arrage into a scene in another sketchup.
                          • dukejazzD
                            dukejazz
                            1. tips
                              Some Sketchup noted Hints: by dukejazz in the making of Another Sketchup Plus Ver. 1.2
                            1 To manually (flush a clipboard) 3d entities clean: Use 3d text tool and copy a leter of text Then [cancel] out.
                            2 Another Sketchup (auto clear clipboard) uses a Cmd.link script to clear clipboard. A ruby API script that could do this, was not found.?
                            3 (Security reasons): Flush clipboard when you leave your work area.
                            4 (Never loose a documents) Make use of making copies of your document in your brower.
                            5 (Smart) Open brower's copies to rework on keeps you saving back to original.
                            6 (Limits gray-out) Keep startup and console loaded plug-ins to small and few.
                            7 (Keeps Skp file size small) In model, components and materials: uses (Via) Save and purge.
                            8 (Watch memory flow:) Task manager: It is normal for parents overhead memory to be larger than a child.
                            9 (Large doc gray-outs) Open a new parent copy of the document to paste back into it, because of larger overhead of note 8.
                            10 (Max File save size) Max file size is by power of zoom extents, and by zoom in/out decreases the save size?
                            11 (Polyreduce if you can) Overworking objects gives higher code counts.
                            12 (Bug splats)HKEY_CURRENT_USER\Software\Google\SketchUp8.
                            a (Find) ToolbarsUser-Summary and ToolbarsUserCustom-Summary.
                            b (via) Right-click_ permission special _ to you full control on and you read off. The resticted and system read only_full control is off . This (Locks) Toolbars to fix num ToolbarsUser_limits overloading your registers.
                            13 By using a Sketchup::require statement, in a rb, loads a rbs scrip to console.
                            14 Fix you startup rbs code to zero by via note 8. Another Sketchup Plus Ver. 1.2 runs as ruby script with extensions.
                            • 2 / 2
