Solid Tools Substract > SU fixes Model > Solid Broken
Hi there,
I use the substract tool a lot. My problem is: when I cut more complicated models, SU wants to fix the model after the cut (I dont want to disable this option). What SU does is to delete all very, very short edges so my new solid model gets broken and has some holes in it. By now I zoom in, redraw those short edges and scale them with factor 40.
I work on rather small scaled models (40 cm width) but use the "Scale with factor 1000" plugin to do my solid substractions (because someone told me that Su cuts better in large scales).
Is there any elegant solution or plugin for this?
Thank you so much!
Cheers
Obi
Register LoginAdvertisement
