    Artisan 2 Wishlist
    44 Posts 17 Posters 6.4k Views 17 Watching
    • P Offline
      Panga
      Yes ! With the ability to crease boundaries !!! A dream's coming true !! Thanks a lot Whaat !!
      • pbacotP Offline
        @jclements said:
        In the context of terrain meshes and site grading, these are my requests.
        1- Allow the tools other than just the Smooth Selection function (such as the sculpt tool) not to move edges and vertices which have the crease attribute.
        2- Have an option for the strength value to correspond to an absolute value relative to the origin. This would allow the user to sculpt berms or scuplt a series of contours to specific elevations.
        I'm going to ask a question here in terms of a request. Maybe this is already possible.
        In the sculpt tool: flatten-- I can work a terrain down pretty well to "flat", and I imagine I'll get better at it-- but it takes some trial and error. I would like to be able to reference a face in the model and have artisan do subsequent sculpt flattening exactly at that plane. I'd like it to work the way Artisan seems to do already, where the edges transition smoothly out of the flattened area...
        I think that for terrain and other applications, it helps where Artisan sculpt tools can directly reflect or take advantage of guides in the model such as contours or laid-out slope framework, and form smooth transitions in the mesh to these forms.
        • W Offline
          Whaat
          Currently, in version 1.2, the first face that is clicked on will be the reference face for the flattening. By holding the SHIFT key and flattening, it will constrain all flattening to a horizontal plane. So, I think this request is already fulfilled in version 1.2 unless I am misunderstanding you.
          The Vertex move tool can utilize inferencing to guides and other geometry in your model so I suggest making use of it for this purposes. For example, to create a berm at a specific height:
          1. Select the area using the Select Brush
          2. Create a soft selection with the Vertex Select tool
          3. Use the Make Planar tool to flatten to the XY plane
          4. Use the Vertex Move tool to move the berm to the proper height (while doing so, you can snap to guides or contours)
          • pbacotP Offline
            Thanks for the advice, Dale. What a treat!
            In regards to the flatten technique, I gathered something like this was happening from my attempts. However within the terrain itself there may.....
            Excellent! I see that the way might be to use the select tool to designate the area, then one can start from a "sample" face on the side and move, with the mouse button down, to the area needing work. Can't wait to try these ideas out! Thanks!
            • 3 / 3
