    Importer in the same wind order
    3 Posts 2 Posters 342 Views 2 Watching
    • G Offline
      giuseppe500
      hello.
      I'm trying to finish a sketchup importer for opengl in c++ .
      My problem is that the shaders that represent the materials of sketchup are five:
      1)front color back color
      2)front color back texture
      3)texture front, back color
      4)double color
      5)double texture.
      in these shaders i use the gl_frontfacing (that return true if the face is front and false if the face is back )for draw the different materials.
      For example ,in case 2: in the pixel shader:
      if(gl_frontFacing)
      gl_color = frontColor
      else
      gl_color = texture color
      ecc...
      I see that the gl_frontFacing return true if the vertexes are in counterclockwise order or the opposite, i'm not remember good, The problem is that in my importer i have some faces that are counterclockwise and others that are clockwise , then i get a wrong model.
      I think that the problem is the indexes order of the vertexes , how i can get all the faces in an unique wind order?
      thanks.
      • TIGT Online
        If you get the face.vertices they won't always return in the direction expected; however,
        face.outer_loop.vertices should always return them counterclockwise around the face normal; with all other face.loops [i.e. holes] return their vertices clockwise ❓
        • G Offline
          giuseppe500
          thanks TIG.
          Now i must find a method for import all faces in correct wing order:
          1)i see that there is a m_pMesh->GetPolygonPointIndex(m_nCurrPoly+1, m_nCurrPoint+1, &m_idx);
          is sufficent have the correct indexes of the vertexes for import all in the correct windorder ?
          2) or i must separate the importation of vertexes like the sketchup example SkpToXml of the sdk?
          The sample project do that:
          extract the loops
          hr = pFace->get_Loops(&pLoops);
          long nLoops;
          hr = pLoops->get_Count(&nLoops);
          //If this is a simple face (no loops)
          if (nLoops==1){/////////////////////////////////////////////////////////////////is a simple face
          //import vertex in counterclockwise order
          CComPtr<ISkpLoop> pLoop;
          hr = pFace->get_OuterLoop(&pLoop);
          CComPtr<ISkpVertices> pVerts;
          hr = pLoop->get_Vertices(&pVerts);
          else ///////////////////////////////////////////////////////////////////is a complex face tessellate it with:
          pFace->CreateMeshWithUVHelper(3, pUVHelper, &pMesh);
          and imports vertex in clockwise order?????
          //there i must place the m_pMesh->GetPolygonPointIndex??? and import in specific order????
          ecc....
          is sufficent????
          Thanks a lot.
