    Ruby Console access from C extension
    10 Posts 4 Posters 748 Views 4 Watching
      tomasz
      I am trying to write directly from a Ruby C++ extension to the Ruby Console through a
      std;;cout << "Text\n";
      and/or
      prinf("Text\n");
      , but have no luck. Nothing shows up in the RC.
      Is not Ruby extension standard output redirected to the Ruby Console?
      I guess I can still try invoking from C++ Ruby method SKETCHUP_CONSOLE.write("Text\n) described in this thread:
      , but maybe there is a way to redirect std:cout to the Ruby Console.
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
      • Dan RathbunD Offline
        Dan Rathbun
        The Sketchup::Console does weird things to std I/O.
        I would say that you need to create a extern "C" { } block, and try to use one of the C Ruby functions.
        /* Your C++ code */
        #ifdef __cplusplus
        extern "C"{
        #endif
        // C code in here
        VALUE
        function tomaz_puts_to_con(str)
            VALUE str;
            int argc;
            VALUE *argv;
            VALUE out;
            out = rb_stdout;
            argc = 1;
            argv[0] = rb_str_new2(str)
            rb_io_puts(argc, argv, out)
        #ifdef __cplusplus
        #endif
        if puts() does not work, try write() (...that happens on the Ruby side.)
        /* Your C++ code */
        #ifdef __cplusplus
        extern "C"{
        #endif
        // C code in here
        VALUE
        function tomaz_write_to_con(str)
            VALUE str;
            VALUE out;
            out = rb_stdout;
            // io_write will convert str to ruby T_STRING
            io_write(out, str);
        #ifdef __cplusplus
        #endif
        I'm not here much anymore.
          Dan Rathbun
          EDIT: note that rb_eval_string(); is slow.
          And I think you can also do:
          /* Your C++ code */
            str = "$stdout.write('some message')\n"
          #ifdef __cplusplus
          extern "C"{
          #endif
          // C code in here
          VALUE
              VALUE str;
              rb_eval_string(str);
          #ifdef __cplusplus
          #endif
          or perhaps right from C++:
          rb_eval_string("$stdout.write('some message')\n");
          • tbdT Offline
            tbd
            I used OutputDebugString and DbgView to view the messages and never had a problem compared with random crashes in Ruby world due stack overwriting.
            you can also create a singleton wrapper if you want to log from Ruby world without going to the slow ruby console.
            SketchUp Ruby Consultant | Podium 1.x developer
            http://plugins.ro
              Ditto. But is there a OSX alternative?
              • tbdT Offline
                tbd
                system this command:
                logger "this is my message in the console.app All Messages"
                http://plugins.ro
                  Thankyou! 👍 👍
                    Dan Rathbun
                    There is the "Log Navigator":
                    https://developer.apple.com/library/mac/#recipes/xcode_help-log_navigator/_index.html
                      Dan Rathbun
                      See docs:
                      • logger
                      • syslog
                      • syslogd
                      EDIT(2018-09-17): The old way of calling system('logger','my log message') seems to have been replaced with a unified system wide logging platform.
                      See: https://developer.apple.com/documentation/os/logging
                        tomasz
                        I have tried the last solution:
                        rb_eval_string("$stdout.write(\"Message\n\")");
                        and it works well. I am using it for debugging purpose, so the speed is not important for me.
                        Thanks!
