    Reverse Faces
    5 Posts 4 Posters 420 Views 4 Watching
      Cubcrafter
      Is there a plugin that will process a file and reverse backward faces?
      I imported a file that was created with Cinema 4 and about half of the faces are reversed.
      The SketchUp file has 136,819 faces.
      Thanks,
      • BepB Offline
        Bep
        Try this:, select a face, than do a right click on it and select orient faces.
        Bep
        "History is written by the winners"
        • FrederikF Offline
          Frederik
          Did you try making a search prior to posting this question...?
          Or did you have a look in the Plugins Index...?
          Any way... The [Plugin] Front Face - 1.2 might help you... πŸ˜„
          Cheers
          Kim Frederik
            Cubcrafter
            Frederik,
            This helps some as did the orient faces command but what I was looking for and could not find was if there was a plugin that would process the whole model without the user needing to select any faces.
            Thanks,
              Before chasing the reversed faces I might be inclined to run Delete Coplanar Edges to perhaps reduce the number of faces that need to be reversed.
