    Back_material of a face
    5 Posts 3 Posters 286 Views 3 Watching
    • K Offline
      kiesewetter
      Hallo!
      I am going to set the material of a face in the following method. To avoid problems with the oriatation of the face's normal I want to set its back_material, too.
      I tried it with the following code:
      def status_anzeigen #funktioniert, nur das mit dem alpha wert im material inplanung noch nicht so
        mod = Sketchup.active_model
        ents = mod.entities
        sel = mod.selection
        mats = mod.materials
        bau_mat = mats.add "im_bau" if not bau_mat = mats["im_bau"]
        bau_mat.color = [255,127,38]
        fertig_mat = mats.add "fertig" if not fertig_mat =mats["fertig"]
        fertig_mat.color = [211,211,211]
        inplanung = mats.add"noch_nicht_angefangen" if not inplanung = mats["noch_nicht_angefangen"]
        inplanung.color = [176,196,222]
        inplanung.alpha = 0.3
        ents.each{|e|
                  if e.typename == "Face"
                       start = e.get_attribute "ablauf", "baubeginn"  #attributes that were assigned to the faces before
                       ende = e.get_attribute "ablauf", "bauende"     #attributes that were assigned to the faces before
                      if (e.material) #checking wehther the faces current material belongs to the ones created at the top of the method, if not, save the name of the current material as an attribut
                         invalid_materials = ["im_bau", "fertig", "noch_nicht_angefangen"]
                         unless invalid_materials.include?( e.material.name )
                           mat_vorher = e.material.name
                           e.set_attribute("ablauf", "material", mat_vorher)
                       if @woche.to_i >= start.to_i && @woche.to_i < ende.to_i #@woche variable of the class
                         e.material = mats["im_bau"]
      				   e.back_material = mats["im_bau"] #why doesn't it work?
                       if @woche.to_i >= ende.to_i
                         e.material =mats["fertig"]
      				   e.back_material =mats["fertig"]  #why doesn't it work?
                       if @woche.to_i < start.to_i
                         e.material = mats["noch_nicht_angefangen"]
      				   e.back_material = mats["noch_nicht_angefangen"]  #why doesn't it work?
      Only the "front" of the face was changed to the new material. Does anybody know what mistake I made?
      Thanks for your time.
      Tim
        Well making the backs and fronts match will improve appearance BUT it won't work with many 3rd party render apps which render all back-faces a default material ignoring their actual back material - and render the front correctly - which is then facing away!
        To make all materials be on both sides is straightforward...
        You seems to be making it more complicated than it needs to be ?
        EDIT: ALSO as Dan points out, your code is also flawed in several places... e.g. '==' compares values, but '=' sets a value!
        Collect all faces in the model
        faces=[];Sketchup.active_model.entities.each{|e|faces << e if e.class==Sketchup::Face}
        Now look at each face and decide what to do
        faces.each{|face| if face.material face.back_material=face.material else # there's no front material if face.back_material face.material=face.back_material end end }
        Now all faces have the same front and back material.
        The front material [if any] takes precedence over the back material.
        If there's no front-material then the back material is also used on the front.
        • Dan RathbunD Offline
          Dan Rathbun
          Lines 6, 8 and 10:
          use the comparison operator ==, not the assignment operator, =.
          I'm not here much anymore.
          • K Offline
            kiesewetter
            But that part of the code:
            should have been working, shouldn't it?
            I don't understand why the materials were assigned to the front, but not to the back of the face.
            any idea?
            • K Offline
              kiesewetter
              working meanwhile... 😳
              thanks for the help.
