    WebDialog.set_html fails under Safari 5.0.6
    111 Posts 7 Posters 20.9k Views 7 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      I wish someone could make a one-click dmg installer for Sketchup Mac that would bring their Ruby up to par with the PC edition.
      I'm not here much anymore.
      • fredo6F Offline
        fredo6
        The problem seems to be in all versions after 5.0.6
        A user encountered the problem on Safari Version 5.1 (7534.48.3): images not shozing and Update (via xmlhttprequest not working)
        Fred
        • P Offline
          Pout
          I'm a bit confused here.
          So if you would use set_file then all should work fine?
          I'm using that method and it loads a html file but the linked js files inside do not seem to work.
          They do however work when just opening the html file with Safari. (So not in a webdialog)
            Yes, set_file should work. Got a sample of what is not working?
            • P Offline
              Pout
              here you go
              unzip, put the rb in plugisn and the Grid directory to
              thx for testing!
              test.zip
              • P Offline
                Pout
                and in SU you can launch by TESTOLA.testing in ruby console
                  driven
                  With your WebDialog in Safari 5.0.6 Web Inspector shows this error
                  TypeError: 'null' is not an object (evaluating 'navigator.userAgent.match(/(?:KHTML\D*|VERSION\D*)(\d[\d\.]+)/i)[1]')
                  I'd look into that to start.
                  john
                    hmm... why are you sniffing the userAgent string? It's preferred to test for features instead of testing the user agent string.
                    • P Offline
                      Pout
                      Well it is in fact not a script written by me.
                      It is an external script which i'm trying to incorporate.
                      So the complete js side is unclear to me.
                      In what file is the error located?
                      Thx again
                        driven
                        Thx again
                        GridE.js
                        It's in encodedstring LZD="....."
                        which I can't look at.
                        john
                        • P Offline
                          Pout
                          driven, thx!!
                          I have reported the error an already received a debugged version (bug at their side)
                          • 6
                          • 6 / 6
