WebDialog.set_html fails under Safari 5.0.6
And also you might try to trap the
SystemExitexeception, which is supposed to be called, unless Google usedexit!()in which case your out of luck.I'm not sure if
Kernel.set_trace_funcwill catch a call toexit!()or not. -
@dan rathbun said:
It's a bit confusing to have your Observer table combined with both platforms, have you thot about having a table for each platform?
Wouldn't having two tables make it harder to get an overview of what observers has issues?
@dan rathbun said:
And just to be clear, your testing using the Ruby ver that ships with the Sketchup version? (v1.8.5-p0)
What happens if your change the Sketchup Ruby symbolic links on the Mac to a newer Ruby install (v1.8.6-p287 or higher?)
Yes - I only test SketchUp out of the box. And that is complicated and time-consuming enough...
I wish someone could make a one-click dmg installer for Sketchup Mac that would bring their Ruby up to par with the PC edition.
The problem seems to be in all versions after 5.0.6
A user encountered the problem on Safari Version 5.1 (7534.48.3): images not shozing and Update (via xmlhttprequest not working)
Fred
I'm a bit confused here.
So if you would use set_file then all should work fine?
I'm using that method and it loads a html file but the linked js files inside do not seem to work.
They do however work when just opening the html file with Safari. (So not in a webdialog) -
They do however work when just opening the html file with Safari. (So not in a webdialog)Yes,
set_fileshould work. Got a sample of what is not working? -
and in SU you can launch by TESTOLA.testing in ruby console
With your WebDialog in Safari 5.0.6 Web Inspector shows this error
TypeError: 'null' is not an object (evaluating 'navigator.userAgent.match(/(?:KHTML\D*|VERSION\D*)(\d[\d\.]+)/i)[1]')I'd look into that to start.
hmm... why are you sniffing the userAgent string? It's preferred to test for features instead of testing the user agent string.
Well it is in fact not a script written by me.
It is an external script which i'm trying to incorporate.
So the complete js side is unclear to me.
In what file is the error located?Thx again
Thx againGridE.js
It's in encodedstring LZD="....."which I can't look at.
driven, thx!!
I have reported the error an already received a debugged version (bug at their side)
