    Help with shadow_info and SunRise
    3 Posts 2 Posters 321 Views 2 Watching
    • JuantxoJ
      Juantxo
      Hello,
      I'm trying to debug this method but I could not find out why the same day has some seconds of difference in Sunrise.
      May be it's not the right form to find out the Sunrise for a given time?
      (I'm using Sketchup 8.04811)
      Please help!
      def fsun(year1,month1,day1,hours1, minuts1)
      	model=Sketchup.active_model
      	info=model.shadow_info
      new_time=Time.local(year1, month1, day1, hours1, minuts1)
      info["ShadowTime"]=new_time
      	p(info["SunRise"])
      fsun(2011, 12, 21, 11, 59)
      fsun(2011,  6, 21,  9, 59)
      fsun(2011, 12, 21,  9, 59)
      #RESULT;
      # Wed Dec 21 08;24;22 +0100 2011 #SunRise should be equal?
      # Tue Jun 21 06;37;23 +0200 2011
      # Wed Dec 21 08;24;31 +0100 2011 #SunRise should be equal?
      # true
      • TIGT
        It's probably just a minor tolerance issue.
        If you can actually measure the sunrise to the nearest minute you'll be lucky!
        The couple of seconds discrepancy are really nothing at all πŸ˜•
        The site's elevation and the relative height of adjacent landscape/buildings towards the rising sun direction will all affect the 'real' time much worse any, so why not be satisfied to the nearest minute or so ?
        PS: 'SunRise_time_t' gives comparable results to 'SunRise' so that's not the issue
        • JuantxoJ
          Juantxo
          I thought I was doing something wrong.
          Then, I don't worry about this discrepancy.
          Thanks Tig
