    How can i reduce a large file size?
    4 Posts 3 Posters 317 Views 3 Watching
      SHARK X
      i made a house and its size is very big (140mb) how can i reduce it to 10mb? because when i try to upload it to 3d warehouse it says file is too big must be less than 10mb
        Hi Shark,
        Well, it is hard to say anything without seeing your model. It can be model complexity - in which case there is not much to do.
        Have you used components for any repetitive geometry? That can reduce file size tremendously.
        Also, if you have any custom images as textures and they are too big, you should edit them and that can also reduce file size.
        Is there any chance you can upload it to some file sharing site (it would be too much here, too)?
        • AnssiA Offline
          Anssi
          The first thing to try is to press the Purge button in the Window menu>Model Info>Statistics dialog a couple of times. This deletes all the things that are embedded in the model file but unused, like components and materials you have tried.
          Anssi
            SHARK X
            i final uploaded it! here is the link of my project http://www.mediafire.com/?2s29lcwwov7v777
