    Rotation Matrix problem
    2 Posts 2 Posters 288 Views 2 Watching
    • C
      Cheesygecko
      Hello, i've working with the ruby api for a few weeks now. I want to mate two components by their construction points (position) and Construction lines (alignment). I compute the global position of the points and move one component to another (so setting the position works fine). The problem is the alignment. I compoute the angle between the axis of the components. I get a correct angle in this part of my code. I also compue the normal vector of the plane that is defined by the two axes. Then i build a transformation matrix that should rotate the component , so the axes are parallel.The result is that they are "almost" parallel and the rotated component shrinks a little.
      Can anyone tell me why this is working this way? Is the matrix correct? Thank you! 😎
      This is my matrix (normal is the axis for the rotation, radAngle is the angle in radians:
      trans = Array.new(16)
      trans[0] = Math.cos(radAngle)+(normal[0]normal[0])(1-Math.cos(radAngle))
      trans[1] = (normal[0]normal[1])(1-Math.cos(radAngle))+normal[2]*Math.sin(radAngle)
      trans[2] = (normal[0]normal[2])(1-Math.cos(radAngle))-normal[1]*Math.sin(radAngle)
      trans[3] = 0
      trans[4] = (normal[0]normal[1])(1-Math.cos(radAngle))-normal[2]*Math.sin(radAngle)
      trans[5] = Math.cos(radAngle)+(normal[1]normal[1])(1-Math.cos(radAngle))
      trans[6] = (normal[1]normal[2])(1-Math.cos(radAngle))+normal[0]*Math.sin(radAngle)
      trans[7] = 0
      trans[8] = (normal[0]normal[2])(1-Math.cos(radAngle))+normal[1]*Math.sin(radAngle)
      trans[9] = (normal[1]normal[2])(1-Math.cos(radAngle))-normal[0]*Math.sin(radAngle)
      trans[10] = Math.cos(radAngle)+(normal[2]normal[2])(1-Math.cos(radAngle))
      trans[11] = 0
      trans[12] = 0
      trans[13] = 0
      trans[14] = 0
      trans[15] = 1
      mat = Geom::Transformation.new trans
      $newComp.transform! mat
      • TIGT
        Rotation and Scaling are inexorably linked in a transformation - hence the weirdness...
        Can I suggest another approach...
        You are trying to align two objects they both have obj.transformation.axes and you can transform in steps...
        Therefore you can move the objects together using
        [ tm=Geom::Transformation.translation(vector_from_point_to_point)]
        and then rotate one to align with
        [ tr=Geom::Transformation.rotation(point, axis, angle)]
        • you can 'combine' transformations thus
          t=tm*tr
          and then use
          obj.transform!(t)
          in one step... but note that the 'order' is important in a matrix * and the order of the transformations it will do is always taken as right-to-left... i.e. the move then the rotation - unlike normal numerical multiplication it's not commutative for matrices! Moving and then rotating will not necessarily give the same result as rotating and then moving - depending on the relativity of points etc...
        PS: Put your code inside a [ code ]...[ /code ] block as it's easier to read.
        You are using a $ variable - dangerous as it's exposed to all other tools and such a common name may well clash with other authors' unwrapped code too... Use @ or @@ variables that span methods within your own module/class only...
        Parenthesize your arguments as method(1, 2, 3) rather than method 1, 2, 3 - although both work upcoming versions of Ruby may well deprecate unparenthesized arguments and even the most recent update caused some problems - I know th API guidance and many example scripts do it the 'wrong way' but it's a good habit to get now, before your code gets out of date unnecessarily...
