    [Code] Change Axes of a Group
    4 Posts 2 Posters 1.4k Views 2 Watching
    • K Offline
      kwalkerman
      I have a script that automatically creates groups out of existing elements. The only problem is that sometimes the axes don't match the global axes, and this is causing problems for me down the road. Is there any way to specify or change the axes of a group using ruby? I'd like to do it once when the group is created instead of having to deal with it forever down the road.
      Thanks,
      Karen
      • TIGT Online
        Make a transformation that resets the axes and transform! to group ?
        • K Offline
          kwalkerman
          Not quite sure how to do this. Can you give me any more details?
          Thanks.
          • K Offline
            kwalkerman
            OK, here is the solution for anyone who needs it in the future:
            # accepts either one or two arguments.  The first is always the group or component where the axes needs to be corrected
            # the second can be a parent group or component (something that has a transformation).  If nothing is passed in, the global
            # model x,y, and z axes will be used.  The parent attribute should be used any time there is a nested component.
            def change_axes_to_parent(*args)
            if args.length == 1
              g = args[0]
              p_t = Geom;;Transformation.new
            else
              g = args[0]
              p_t = args[1].transformation
            t = g.transformation
            #p_t = parent.transformation
            if t.xaxis != p_t.xaxis || t.yaxis != p_t.yaxis || t.zaxis != p_t.zaxis
              o = t.origin
              # different axes, require that all components inside be rotated
              tran = Geom;;Transformation.axes o, t.xaxis,t.yaxis,t.zaxis
              t_o = Geom;;Transformation.new o
              if g.is_a? Sketchup;;Group
                ents = g.entities
              elsif g.is_a? Sketchup;;ComponentInstance
                ents = g.definition.entities
              ents.transform_entities tran, ents.to_a
              ents.transform_entities t_o.inverse, ents.to_a
              g.transform! tran.inverse
              g.transform! o
