    Getting user home directory
    4 Posts 3 Posters 358 Views 3 Watching
      draftomatic
      As I google for a solution it seems that people use either ENV['HOME'] or File.expand_path('~').
      Neither of these work on PC since it looks like the variable is HOMEPATH instead. So I was just hoping for a sanity check and wondering what others are doing here. Will this be reliable?
      if (WIN)
        userPath = ENV['HOMEDRIVE'] + ENV['HOMEPATH']
      elsif (MAC)
        userPath = File.expand_path('~')
      • Dan RathbunD Offline
        Dan Rathbun
        See my code example:
        [ Code ] !autoload.rb loads "!_autoload" folders
        and FYI:
        ](http://www.ruby-doc.org/core-1.8.6/classes/File.html#M000794)":1laxg9xj]
        File.expand_path(file_name [, dir_string] ) → abs_file_name
        Converts a pathname to an absolute pathname. Relative paths are referenced from the current working directory of the process unless dir_string is given, in which case it will be used as the starting point. The given pathname may start with a **` ~`**’’, which expands to the process owner‘s home directory (**%(#008000)[the environment variable HOME must be set correctly]**.) ~user’’ expands to the named user‘s home directory.
        I'm not here much anymore.
          Surely ENV["USERPROFILE"] gives it in one step ?
            Dan Rathbun
            As my code does:
            ENV['HOME']=ENV['USERPROFILE'] unless ENV['HOME']
            ENV['USER']=ENV['USERNAME'] unless ENV['USER']
            # now set a global;
            $HOME = ENV['HOME']
            # .. or use the tilde shortcut within pathstrings.
            BTW.. the " ~*user*" feature does not work on Windows. Likely because of Security issues.
