    I need help about style
    9 Posts 3 Posters 888 Views 3 Watching
      ch1cken09
      i very like this style, but i dont know how to have or creat it, who can help me creat this style or if you have it, share it for me, thank you very much! πŸ˜„
      http://i237.photobucket.com/albums/ff216/nthanhsawyer/3335766174_cbc6b1ffd4_b.jpg
      http://i237.photobucket.com/albums/ff216/nthanhsawyer/3335761162_e6363df656_b.jpg
        It seems that nothing is very special in this style. It is a simple "Shaded with textures" face style (well, the modeller did not use too many image materials but mainly colours) otherwise these settings are somewhat the ones which would produce a similar look - I guess there is a 1 pixel profile set as well since some curved geometry (cars) display their outlines, too (trees are apparently set to have translucency)
          ch1cken09
          Thanks for sharing. I tried your way, but the results do not like 😞 😞
            Well, maybe use longer extension lines and export at a larger scale (say double the size) you need and resample the image in an image editor afterwards. I am pretty sure there is nothing very tricky in that style.
              ch1cken09
              Here are my results, it's not like the that style, a style that seems to be on formfonts.com. but I don't have an account to download 😞
              http://i237.photobucket.com/albums/ff216/nthanhsawyer/Ori.png
                Well, to me they are quite similar (even if they are not the same exactly). Maybe adjust the shadow darkness/lightness slider a bit to have somewhat less contrast.
                If the style is at FormFonts, the only way you can get the original is to subscribe to FF. No-one is allowed to share (or even ask for) copyrighted material here (see #4 of our TOS you agreed when registering here). πŸ˜’
                  ch1cken09
                  thank you very much! i will try! but if you can creat this style in future, please share it for me! πŸ˜„ thank you! πŸ˜„
                    I'd share any style here for sure - although I am not a very "stylish" person (you should see me live) πŸ˜„
                      There is definitely some post-processing done in the original example. Reflections have been added and I suspect those long lines running through the sky are added afterward, too.
                      I think a major difference between your image and the examples is their use of simple, transparent trees. You could edit yours to make them transparent which would help.
                      I have made quite a few styles but wouldn't presume to copy an existing one even if it is commercially available one. If you really want that style, you should get it from Form Fonts.
