Color the component according to dynamic component attribute
I am new in ruby programming, and I was trying to execute following code in skectchup but it's not working.
UI.menu("Plugins").add_item('paint Red') { model = Sketchup.active_model entities = model.entities.to_a attr = [] if e.get_attribute('dynamic_attributes','condition','')=="1" attr << e end entities_def = entities.definition entities_def.set_attribute 'dynamic_attributes', 'material', 'red' entities_def.set_attribute 'dynamic_attributes', '_material_formula', '"red"' dcs = $dc_observers.get_latest_class dcs.redraw_with_undo(entities) }What I was trying to do is -
I have many components in sketchup model. All those components have dynamic attributes 'material' and 'condition'. I was trying to assign material color "red" to all the component with attribute condition = 1.I took help to write above code from following link:
http://forums.sketchucation.com/viewtopic.php?f=180&t=24241&p=331242&hilit=select+object+as+per+attribute#p331242 -
This could be done using features which are already available in Dynamic Components.
Try adding the built-in Material attribute, and use a formula similar to the following:
Material: =if(condition = 1, "Red", "Default" )I realize there may be a good reason to use an extra Ruby script to accomplish this, but I thought I'd point this out since it's fairly simple to do.
(The use of "Default" as a material name causes an error in the formula, but has the effect of removing any applied material. I don't see how to remove materials in a DC.)
I don't know how to execute
@unknownuser said:Material: =if(condition = 1, "Red", "Default" )
.I have edited the previous code and still is not working..
UI.menu("Plugins").add_item('painting Red') { model = Sketchup.active_model entities = model.entities.to_a entities_def = entities.definition condition_1 = [] entities.each{|e| if e.get_attribute('dynamic_attributes','condition','')=="1" condition_1 << e end } entities_def.set_attribute 'dynamic_attributes', 'material', 'red' entities_def.set_attribute 'dynamic_attributes', '_material_formula', '"red"' dcs = $dc_observers.get_latest_class dcs.redraw_with_undo(entities) }here shortcut references are:
%(#FF0000)[model = Sketchup.active_model
entities_def = entities.definition]I tried to select all the components with dynamic reference 'condition =1" in following code:
condition_1 = [
entities.each{|e|
condition_1 << e
}]And, for the above selection, I tried to change the material (of dynamic reference) into red color in following code:
%(#FF0000)[entities_def.set_attribute 'dynamic_attributes',
'material', 'red'
'_material_formula', '"red"']Actually, I don't know what the codes
dcs = $dc_observers.get_latest_class dcs.redraw_with_undo(entities)means, but I copied that code form the base file I used from the following code:
UI.menu("Plugins").add_item('Make Sang Red') { # Assumes that sang is the 1st entity in model. sang = Sketchup.active_model.entities[0] sang_def = sang.definition # Override sang's shirt color to red. ("material" # is a special attribute that requires # you to set a formula to "take control" # over the default material the user has painted.) sang_def.set_attribute 'dynamic_attributes', 'material', 'red' sang_def.set_attribute 'dynamic_attributes', '_material_formula', '"red"' # Add a new configurable option to Sang. # (Any attribute that starts with an underscore # is a "meta attribute" that describes behavior.) sang_def.set_attribute 'dynamic_attributes', 'weight', '145' sang_def.set_attribute 'dynamic_attributes', '_weight_label', 'weight' sang_def.set_attribute 'dynamic_attributes', '_weight_formlabel', 'My Weight' sang_def.set_attribute 'dynamic_attributes', '_weight_units', 'STRING' sang_def.set_attribute 'dynamic_attributes', '_weight_access', 'TEXTBOX' # Change the description that shows # up in the configure box with a custom # formula. sang_def.set_attribute 'dynamic_attributes', '_description_formula', '"Sang is now red and weighs " & weight' # There is a global handle into the plugin that # allows you to make the same calls that the # plugin does, like so... dcs = $dc_observers.get_latest_class dcs.redraw_with_undo(sang) }Thank you.
I assumed you were usung SketchUp Pro. Try this:
UI.menu("Plugins").add_item('painting Red') { BlueOrchid.paint_red } module BlueOrchid def self.paint_red Sketchup.active_model.entities.to_a.each{|e| if e.get_attribute('dynamic_attributes','condition','')=="1" e.definition.set_attribute 'dynamic_attributes', 'material', 'red' e.definition.set_attribute 'dynamic_attributes', '_material_formula', '"red"' $dc_observers.get_latest_class.redraw_with_undo(e) end } end end -
thanks a lot. it worked. You saved my day...
How do u guys learn ruby for sketchup? What are the basic requirements (computer knowledge) to start ruby?
I wish i could learn efficiently and quickly.Thanks again.
Register LoginAdvertisement
