    Ruby Script for coloring the selected objects
    4 Posts 3 Posters 1.4k Views 3 Watching
    • H Offline
      hchitrakar
      I am a newbie in both sketchup and Ruby
      The following is the part of ruby script I am working right now
      cmd1 = UI;;Command.new("Show 01") {show_1}
      cmd1.set_validation_proc {
      true ? MF_ENABLED ; MF_GRAYED
      cmd1.small_icon = "01_small.png"
      cmd1.large_icon = "01_large.png"
      cmd1.tooltip = "Show layer 01 with materials"
      toolbar1 = UI;;Toolbar.new "Color the objects"
      toolbar1.add_item cmd1
      toolbar1.show
      Till now, I am only able to create the icon on the toolbar with the image "01" I tried a lot to let the icon execute some commands but I failed all the time. (Still working on this for more than 72 hrs)
      What I wanted to do is -
      1. When some faces or entity is selected on the sketchup, and then, if I pressed that icon, I wanted to apply either color (from material library, such as color_A01),or texture (any jpg) on those selected face. Is it possible to do this?
      2. Another thing I wished to do was put a roll down menu which gives the names of all the layers present in the sketchup model and when i press above mention key "01", it should select all the objects in the layer chosen and apply color or texture. Is it possible to do this?
      I prefer color than texture.
      How shall I do it?
      Thank in advance
      • TIGT Online
        At the moment your button runs something called 'show_1'.
        Keep the Ruby Console open as you are testing your script...
        What happens when you click the button?
        I won't go into the complexities of tools/class/module [yet] - but you should structure your tools approrpiately... but for now if you have some code in the same file like this
        def show_1() UI.messagebox("'show_1' has run!") end
        on a restart the button should open the message ??
        If you have that running you are on the road to success...
        Inside the method add your code.
        Have you read examples of other scripts doing something similar - if not, do so now...
        Also Read the on-line API notes...
        At the start of you code set some shortcut references to save typing
        model=Sketchup.active_model ss=model.selection materials=model.materials layers=model.layers
        Now check what is in the selection... in this example we extract the faces
        faces=[] ss.each{|e|faces << e if e.class==Sketchup::Face}
        Now process the faces
        faces.each{|face| face.material='Red'}
        There is a standard list of colors that can be called directly like 'Red', 'Black' etc, if they aren't in the model's materials then they are added, using the color's name and the appropriate RGB values.
        You CANNOT load material-files [SKMs] from external libraries [at least not without special tools that I have invented - but we are talking about basic API here!].
        You can use any material already in the model's materials.
        You can add a new material to the model's materials.
        You can change the color [RGB] of any existing material.
        You can change the transparency of any existing material.
        You can add an image-file as the texture of any existing material.
        So let's assume we have an existing material called 'MyMaterial' to use it simply specify its name as face.material='MyMaterial' or mat=materials['MyMaterial'], then face.material=mat...
        Let's now assume we want to make a new material called 'MaterialX'... you do this...
        matx=materials.add('MaterialX') and it's added as black [0,0,0], solid material, with no texture.
        If it already existed then this new material is named 'MaterialX1'.
        To adjust it's color use
        matx.color=[0,255,0]
        Here we've made it 'green'
        To give it transparency use
        matx.alpha=0.5
        To add a texture is more complex...
        matx.texture.filename="C:\\....\\materialX.jpg"
        you add the path needed...
        You can adjust the texture's properties too - like its size.
        You can also get the avc=matx.texture.average_color and use that as the material.color=avc so when view mode is without a texture it's approximately the same color...
        So you can see there are lots of possibilities...
        You can't add dropdown menus to a toolbar button - you can add them to an inputbox [or a webdialog - but that's a bit complex at the start].
        Let's see how we might make a list of layer names...
        ` defname='Layer0'
        or whatever it's called in your locale
        layer_names=[]
        model.layers.each{|e|layer_names << e.name unless e.name==defname}
        layer_names.sort!
        layer_names=[defname]+layer_names
        this is a sorted list of layer names with 'Layer0' at the start
        as in the native Layer Browser pane.`
        Now for the inputbox...
        ` joined_names=layer_names.join("|")
        they need to be in the form 'Layer0|AA|AB|BBB' etc
        prompts=["Layer: "]
        values=[defname]
        drops=[joined_names]
        title="Choose Layer"
        results=UI.inputbox(prompts,values,drops,title)
        return nil if not results
        i.e. the user pressed Cancel
        layer_name=results[0]
        layer=model.layers[layer_name]`
        Now apply the layer to 'object'...
        [ruby:35i6hjzv]object.layer=layer[/ruby:35i6hjzv] etc etc
        • Dan RathbunD Offline
          Dan Rathbun
          Ruby Newbie's Guide to Getting Started
          I'm not here much anymore.
          • H Offline
            hchitrakar
            Thank you very much. The code worked and will be uploading soon...
            And I am learning ruby for sketchup from basics now..
