    Explode 1 level component
    8 Posts 3 Posters 477 Views 3 Watching
    • G Offline
      glro
      I have components containing components(nestled components? sub components?)
      I would like to explode only the first level of components, to keep the information contained in the sub components
      i tried this code
      ent = mod.entities
      	for e in ent
      		if e.is_a? Sketchup;;ComponentInstance
      			e.explode
      but instead on exploding only the initial components once, it seems that sketchup explodes completely the first component, then the sub components of the first initial component, ...
      is there a way to explode only once the initial components?
      2 nestled components
      some components a exploded twice, and others never
        Use ents.to_a - that freezes the list; if you use ' ents' it keeps looking into what's available in the 'entities' and it will find some things that have just been added from the one you've just exploded !
        • G Offline
          glro
          Yes, this is exactly what was happening
          i made the correction
          ents = mod.entities
          ents.to_a
          for e in ents.to_a
                   e.explode
          and now it works perfectly
          Thank you very much; it took you a few seconds, while i had been looking for a solution the whole day...
          • jolranJ Offline
            jolran
            😄 I know the feeling
            Does this give the same result for you? I've heard iterators are a good bet.
            I'm just a hack, just something I picked up..
            Acctually looking for the contrary of what you are, exploding everything that's nested.
            So I will try the opposite of what TIG recommended for you. Good thread!
            ents.to_a.each{|e|
            	      next if not e.valid?
            	       e.explode if e.class==Sketchup;;ComponentInstance
            • G Offline
              glro
              ents.to_a.each{|e|
              >   end
              No, what i get is:
              Error: #<SyntaxError: (eval):8:in `initialize': compile error
              (eval):8: syntax error, unexpected kEND, expecting $end
              To explode nestled components, maybe you could try this
              http://www.smustard.com/script/Bomb
              • jolranJ Offline
                jolran
                oh sorry typo. You need to incoperate it with the rest of your script and put "end".
                Never mind.. I probably to green to give any advice.
                Will have a look at that bomb, thanks!
                  You have a superfluous 'end' after the '}'.
                  The 'for...end' is similar to the '..each{...}'
                  The block is '{...}' so the 'end' is not needed [unless of course it's part of a longer piece of text - e.g. it's needed to close a method 'def', an 'if' test etc]
                  • jolranJ Offline
                    jolran
                    So I was wrong in everything I said 😄
                    Yes it was part of some longer piece, I copy and pasted it wrong, sorry.
