    Dynamic Components Attributes
    10 Posts 5 Posters 1.9k Views 5 Watching
    • F Offline
      FlorianCH
      Hello Guys
      How do I combine different attributes from different components together, so that I have only to do 'one click' and then all attributes from all components will be executed together? πŸŽ‰
      Thank you a lot for your answers. β˜€
        Hi Florian,
        I am a complete idiot when it comes to dynamic components that are a bit more sophisticated than just a single attribute but we have a specialized subforum for them under the main SU forum so let me move your topic there for better attention...
        • F Offline
          FlorianCH
          Hi Could you give me please the new link from my post? Thanks a lot.
            You are already in your post. When we move a topic, we usually leave the "shadow topic" in the original forum. This is marked with a small arrow in its icon. Then it's actually a link to the moved topic.
            (Another note: Use the "Reply" button at the bottom left to reply and not the "Report" button as reports can only be seen by moderators. I have now copied your report into a post above)
            • AnssiA Offline
              Anssi
              DC attributes cannot be transferred between different components, so the thing to do is to put them as subcomponents within a "parent" component. Then you can make the attributes in the "child" ones react to attribute changes in the parent. If I remember right, this works through 2 levels of nesting.
              Anssi
                sketchdata
                http://youtu.be/-nzDHYvxQGw links to a youtube video demonstrating a plugin that changes common DC attributes across multiple DC components at one time, it's about 3 minutes into the video. This plugin was my solution to the attribute levels, and was created to help kitchen Designers to change door styles and/or toekick heights over multiple DC cabinets at one time, maybe this will help?
                • F Offline
                  FlorianCH
                  @Anssi
                  Thank you for your solution. That was exactly the point I have searched for. πŸ‘ It works great but do you (or someone other) know how I could make, that the components don't move at the same time? I mean for example at a door, that the handle first goes down and the door went open after that.
                  • F Offline
                    FlorianCH
                    @sketchdata
                    Thank you for your effort. But I don't think that this video could help me. In my sketch I haven't the same attributes in my components.
                      Jim
                      Hello,
                      This post may help with consecutive animations.
                      • F Offline
                        FlorianCH
                        And there isn't an easier way ❓
