    How to check registry for pro version?
    6 Posts 4 Posters 487 Views 4 Watching
      mhd
      I think the topic says it all: I need to check in the registry whether the pro or free version is installed. Can anyone help me?
        The method
        Sketchup.is_pro?
        tells you if the current version of Sketchup running is Pro.
        This code tells you which ' Pro' versions are installed [PC only]
        def pro_installed?()
          if [PLATFORM].grep(/mswin/)!=[PLATFORM]
            UI.beep
            puts 'Windows method only!'
            return nil
          end#if
          cmd='pro_installed.cmd'
          txt='pro_installed.txt'
          file=File.new(cmd,'w')
          file.puts('reg query "HKCU\Software\Google" | find "SketchUp" | find " Pro" > pro_installed.txt')
          file.close
          UI.openURL(cmd)
          sleep(0.1)
          result=IO.read(txt)
          File.delete(cmd)
          File.delete(txt)
          return result
        usage: copy+paste all of this code into a file ' pro_installed.rb' in the Plugins folder
        and restart, then type: pro_installed?
        or add as a 'method' in other code...
        returns:
        HKEY_CURRENT_USER\Software\Google\SketchUp7 Pro
        HKEY_CURRENT_USER\Software\Google\SketchUp8 Pro
        etc
          Jim
          TIG, what if the user installed Pro, then let it expire? Does the Pro reg key still exist? I think it might.
            Yes... it just tells you if 'Pro' has been installed... but the question was, 'Is Pro installed?' and this code might effectively return, 'Yes it is!'... or 'No it's not!'... even if it's now expired!! So the code does 'what it says on the tin', and what was asked for πŸ˜’
            I can't see how we might tell if the Pro version is 'valid' or 'licensed' ??
            So, the Sketchup.is_pro? is likely to be the only route, and can only be used when Sketchup is open... πŸ˜•
            • Dan RathbunD Offline
              Dan Rathbun
              The API has a method, but it's defined in the wrong place (which is why you overlook it. I reported this, but basically, Scott said that it was to late to change, or move it, which of course I disagree with. The method might be cloned into the Sketchup module.)
              see: Model.get_product_family()
              Perhaps something like this may make it easier to use ??
              module Sketchup
                def self.get_product_family()
                  self.active_model.get_product_family()
                end #def
              end #module
              I seem to recall during beta, that there may be issues with this method.
              I'm not here much anymore.
                mhd
                I just tested that. It seems the registry keys get deleted if you uninstall SU Pro. I will use this to check for my program. It's not ideal, since you could probably have a pro version running as a free version, but better than nothing πŸ˜„
                Thanks!
