    Issues with the onMouseMove method within a Ruby Tool
    7 Posts 4 Posters 729 Views 4 Watching
      dagobo
      Hi all,
      I've got some troubles to understand the view.invalidate command implemented inside the onMouseMove method within a Tool Ruby script.
      This method is called to refresh the view and to allow the tool to draw some temporary graphics.
      If I want the draw method to draw something different either I clicked once or twice, can I create two draw methods (draw1 and draw2) ?
      Or should I use a variable (first_click=true or false) to tell the draw method which graphic it must draw ?
      Eventually, I don't want the draw method to draw simple lines in real time, but I want a component attribute to be modified (LenX) and immediatly displayed when the onMouseMove method is active.
      It is a bit like the Push-Pull method : can I tell the draw view to update the LenX attribute's value in real time and to display immediatly the component with the good dimensions ? Or should I use another method than the draw method to allow my onMouseMove method to do that in real time ?
      Thanks a lot for your help,
      Marie
      • sdmitchS Offline
        sdmitch
        dagobo, to start, you could add a variable @first_click = false, then in the onLButtonDown or onRButtonDown methods toggle it by @first_click = !@first_click. In the draw method, use a if then else statement to draw different things given the state of @first_click.
        http://sdmitch.blogspot.com/
          Jim
          SketchUp tools are event-driven - you do not decide when when the methods (defined by the Tool interface) are called - SketchUp calls them. What you need to do is decide how to react depending on the state of your tool.
          Here's a very basic example:
          class MyTool
            def activate
              @state = 0
            def onLButtonDown(flags, x, y, view)
              @state += 1
            def onMouseMove(flags, x, y, view)
              case @state
                when 1; # Do this
                when 2; # Do that
                when 3; # do the other thing
            dagobo
            Thanks Jim.
            I am actually trying to implement my draw method within my tool ruby script that way :
            def draw view
            	@component.set_attribute("dynamic_attributes","angle_h", @angle_horizontal_degres)
            	@component.set_attribute("dynamic_attributes","angle_v", @angle_vertical_degres)
            	$dc_observers.get_latest_class.redraw_with_undo(@component)
            The draw method is called within my onMouseMove method.
            What I am trying to get is to make my tool draw and direct my component (@component) towards the right direction (given by both the attributes "angle_h" and "angle_v").
            For now, my script doesn't return any error message, but it doesn't do the right operation.
            My component is directed toward the same direction each time I compute the script, which is not the good direction.
            The lines I use to direct the component are perfectly working within my onLButtonDown method, but not within my onMouseMove method (through the draw method) as you can see.
            How could I fix this ?
            Thanks a lot,
            Marie
              def draw(view)
              is a standard method within a Tool class that is auto-called by Sketchup when any event happens that needs a [re]draw - like a onMouseMove ... you don't need to specifically 'call' it in your own code 😕
              http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#draw
              Don't use draw but rather a new method called say def update() that is explicitly called from your onMouseMove method when certain conditions are met like so '@state' checking tests... Leave 'draw' to do it's own thing like draw some temporary graphics etc...
                dagobo
                OK so if I make a simple draw method that way :
                def draw(view)
                	view.line_width = 3
                and if I create a draw_beam method that way :
                def draw_beam()
                which I can call inside my onMouseMove, will it work correctly ?
                  Why ask me?
                  You are the one with all of the code...
                  Just test it.
                  You need to call your method self.draw_beam() within the onMouseMove method - probably after you've test for a certain 'state' being reached - e.g. perhaps initially 'draw_beam' doesn't kick in with @state=0, but after you have done some other stuff when you've then set @state=1 - then in the onMouseMove method the line would be self.draw_beam() if @state==1 etc, later on, perhaps after you click again, you'd set @state=2 so then the 'draw_beam' stops...
