    Get an origin point inside a Dynamic Component
    4 Posts 2 Posters 636 Views 2 Watching
    • D
      dagobo
      Hi all,
      I want to get the coordinates of an origin point inside my Dynamic Component.
      I created a Dynamic Component composed of three sub components.
      Every sub component has an origin point and axis to get oriented in a different way.
      I want to get the origin point position of one of the sub component in order to use it in my Ruby code.
      I actually want to draw a line from this origin point to the point of the mouse's current location, inside of a onMouseMove method within my Tool Ruby code.
      Does anybody know an answer ?
      Thank you every one,
      Marie
      • TIGT
        Try transformation origin - for the nested-dc's instance and the container-dc's instance...
        Perhaps with adjustments for their relative placements too...
        http://code.google.com/apis/sketchup/docs/ourdoc/transformation.html#origin
        • D
          dagobo
          But will the Point3D returned by the transformation method be the same point I decided for the origin of my sub component when I created it in SketchUp ? (in SketchUp : right-clic on the component, "Modify axes")
          And if I named the sub component ("Light_Beam") of my component ("Light"), could I get directly the sub component from the selection ?
          Instead of writing :
          selection=Sketchup.active_model.selection
          sub_component = selection[0].definition.entities[2].definition.instances[0]
          to get my sub component, and then get the origin point with sub_component.transformation.origin
          The [] method is said not to be very efficient in the Google SketchUp Ruby API. And I don't want to use the .each method as I want to get only one sub component I named.
          • D
            dagobo
            I tested it and it is actually the good origin point which is returned by the .origin method.
            I need to call the method for the nested component as I decided another point for the container component's origin.
            And I will use a for loop to get the right subcomponent (with the right name).
            Thanks a lot !
            Marie
