    Get rotation(transformation)
    31 Posts 3 Posters 1.9k Views 3 Watching
    • jolranJ Offline
      jolran
      Hi I was wondering if there is some simple method of getting the rotation of a group compared to world axis?
      Or do one have to make a complex comparison?
      In the picture, the edge is created from boundingbox.diagonal. Pt1 and pt3 and then grouped. It need to be a group for copying later on.
      I want the user to be able to determine the angle of the edge. Since the diagonal does change according to the boundingbox shape. I will need to reset the rotation and add user desired rotation.
      In this example I'm refering to the X-axis Or rotation around the Y-axis more precisely.
      Ultimately I would want this method for all axis, or rather like in the small picture. Sketchups views. It wont
      work with for ex 33.45 degrees angles, cause I cant determine PT for boundingbox.diagonal.
      Sketchup views would be sufficient in most cases.
      Any tips would be great.
      • jolranJ Offline
        jolran
        Hmm Maybe this?
        http://forums.sketchucation.com/viewtopic.php?f=180&t=35018&p=310308&hilit=edge+angles+on+rectangle#p310308
        Maybe TIG's comparison. vec1.angle_between(vec2) ?
        Something like vec1 = pt1, pt3 and vec2 = pt1, pt4? (simply put)
          The edge has a start and an end which gives you two points ps=edge.start.position pe=edge.end.position.
          It also has a vector
          ve=edge.line[1]
          These are transformed by the container's transformation so you can apply tr=container.transformation to them...
          ps.transform!(tr) pe.transform!(tr) ve.transform!(tr)
          now they are all as they are inside the container's transformation...
          To find the edge's rotation around the Z-axis, 'flatten' the points
          fzps=ps.clone; fpzs.z=0 fzpe=pe.clone; fpze.z=0 fzve=fzps.vector_to(fzpe)
          You can now use the fzan=fzve.angle_between(X_AXIS) to return the rotation around the Z-axis relative to the X-axis.
          Similarly you can flatten in the other two axes to find the rotation around the X or Y axes, relative to say Y and Z axes...
          πŸ€“
          • jolranJ Offline
            jolran
            This is great help. πŸ‘
            The ruby API examples are a little difficult to understand. Now I have something new to work on!
            Thank you TIG!
            • jolranJ Offline
              jolran
              I couldent find any "container" in the API. Does that mean boundingbox or entity-container perhaps?
              Anyway i figured out a way through the API to get what I want. Just need to copy the lines on the
              vectors direction. pt1 and pt6. Further down is noted where I have problems.
              I will have to make an ekvation based on user_input "distance between lines" and how many times to copy to
              clear(pass by) pt 6. Any thoughts?
              Code is very unfinished I guess.
              mod = Sketchup.active_model # Open model
              ent = mod.entities # All entities in model
              sel = mod.selection # Current selection
              face_group = ent.add_group(sel)
              Sketchup.active_model.selection.add( face_group )
              bbox = face_group.bounds
              bpt1 = bbox.corner(0)
              bpt2 = bbox.corner(1)
              bpt3 = bbox.corner(2)
              bpt4 = bbox.corner(3)
              bpt5 = bbox.corner(4)
              bpt6 = bbox.corner(5)
              bpt7 = bbox.corner(6)
              bpt8 = bbox.corner(7)
              pt1 =bpt1
              pt2 =bpt2
              pt3 =bpt3
              pt4 =bpt4
              pt5 =bpt5
              pt6 =bpt6
              pt7 =bpt7
              pt8 =bpt8
              x_cen = bbox.center
              x_vect = pt1.vector_to pt4
              diag_vect = pt1.vector_to pt6
              x_ang = x_vect.angle_between(diag_vect).radians
              user_input = 30   # will get shorter alias
              user_length = 20 # will get shorter alias
              h_group =ent.add_group()
              line_group=ent.add_group() ###==new empty group
              line_group.entities.add_line(pt1, pt6)
              tr1 = Geom;;Transformation.rotation x_cen, [0,1,0],(x_ang).degrees
              tr2 = Geom;;Transformation.rotation x_cen, [0,1,0],(user_input).degrees
              #tr3 = Geom;;Transformation.translation pt4
              ent.transform_entities tr1, (line_group)
              ent.transform_entities tr2, (line_group)
              #ent.transform_entities tr3, (line_group)
              vector=diag_vect
              gp=line_group
              groups=[gp]
              15.times{|i|
              tgp=gp.copy
              # code below does not work. Wanto translate in vector * 20(user_length)
              tgp.transform!(Geom;;Transformation.translation(vector)*(user_length))
              gp=tgp
              groups << gp
                Doh!
                I used the term 'container' to refer to the generic 'entities container'...
                So the 'model' has 'entities'
                Any 'group' in the model has 'entities'
                Any 'component-definition' in the model had 'entities'...
                [Whereas the component-instances in the model have definitions that have entities...]
                So when I say 'container' think of it as the "thing that contains the entities you are interested in"...
                Can't comment on your code... too busy - any takers ??
                • K Offline
                  kyyu
                  Do you want the translation vector to have a length of: "user_length = 20" ?
                  vector.length = user_length
                  tgp.transform!(Geom;;Transformation.translation(vector))
                  • jolranJ Offline
                    jolran
                    I suspected it was something like that you meant. I'm so new on this so I dont grasp the "talk"
                    donte walk the walk etither πŸ˜„
                    Hi Kyyu. I want to have multiple copies in vector direction. User-length is the amount of distance
                    between copies. In this case 20.
                    I should have documented my code better. Its difficult to understand want I am trying to do.
                      Once you have transformed the vector you can change its length using my_transformed_vector.length=20.0 all of the values will adjust to suit the new length BUT the vector's length will then be 20"...
                      • jolranJ Offline
                        jolran
                        YEY! That works!
                        I dont know if it will matter if the vector gets shortened, just yet.
                        Was thinking of grouping the result. Make an duplicate. Scale -1 in vector and do an intersect with.
                        You probably figured out already what this plugin will do.
                        Thank you TIG!
                          Could we go back a few steps and explain what 'it' is you are trying to achieve - it may be much easier that you think...
                          • jolranJ Offline
                            jolran
                            Yes, I hope soo πŸ˜„
                            Ok. So the idea is to make a Hatchplugin.
                            First step is to use sketchup tools and make a face. Wall, rectangle whatever. Select it and run the plugin
                            with a simple promt.
                            In general getting input from user about desired line_angle and distance between them.
                            Make the lines and some sort of grouping before intersect_with method.
                            Wich hopefully will give the result of hatched lines.
                            So by using boundingbox One can use the plugin on unregular faces, not just squares.
                            I wish then to copy lines across the diagonal in the boundingbox, making sure I get edges in the corners.
                            Why boundingbox? For ex. If I have an edge that is 45 degrees com to X , copying that line from center in an array straight up in Z until it reaches the boundingbox will leave the corners uncovered.
                            Maybe if I new how many copies to clear the boundingbox with the last copy of edge that may be an easier
                            method. But that all depend on how the boundingbox is shaped?
                            Same goes for copying along the diagonal.
                            You may be right, there might be some easier method of doing this. But I'm no math expert and struggling here
                            understanding what I just did.
                            Help would be very welcomed, and mentioned if I get this to work πŸ˜„
                              Well... here's how I'd do it...
                              <span class="syntaxdefault">module&nbsp;TIG<br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">hatchfaces</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;ents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />&nbsp;&nbsp;&nbsp;&nbsp;name</span><span class="syntaxkeyword">=</span><span class="syntaxstring">'Hatching#1'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">defs</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />&nbsp;&nbsp;&nbsp;&nbsp;spacing</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">2.0&nbsp;</span><span class="syntaxcomment">###&nbsp;2&nbsp;inches&nbsp;###<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">ss</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />&nbsp;&nbsp;&nbsp;&nbsp;faces</span><span class="syntaxkeyword">=[];&nbsp;</span><span class="syntaxdefault">ss</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'hatchfaces'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">names</span><span class="syntaxkeyword">=[];&nbsp;</span><span class="syntaxdefault">defs</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">names&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instances</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">name&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">?}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">next</span><span class="syntaxkeyword">!&nbsp;while&nbsp;</span><span class="syntaxdefault">names</span><span class="syntaxkeyword">.include?(</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">name<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;gents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">gp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;face</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">bb</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bounds<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;di</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">bb</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">diagonal<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;pt</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">position<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ve</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">po</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.clone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">rotation</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">45.degrees</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">di</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">2<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;tot</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;until&nbsp;tot</span><span class="syntaxkeyword">>=</span><span class="syntaxdefault">di<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ps</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_line</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">ps</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">!(</span><span class="syntaxdefault">ve</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">spacing</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">ps</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">po</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">po</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">vp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_line</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">ps</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">pe</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">po</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">!(</span><span class="syntaxdefault">ve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">spacing</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">tot</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">tot</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">spacing<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end</span><span class="syntaxcomment">#until<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new()<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">intersect_with</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;and&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge&nbsp;</span><span class="syntaxkeyword">and&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">gents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!&nbsp;if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?&nbsp;and&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />&nbsp;&nbsp;end<br />end<br /></span><span class="syntaxcomment">###&nbsp;usage;&nbsp;select&nbsp;faces,&nbsp;TIG.hatchfaces<br />&nbsp;</span><span class="syntaxdefault"></span>
                              • jolranJ Offline
                                jolran
                                WOW, you rewrote the whole script?!!! You are quite amazing. But, but.. Its your plugin, then??
                                Heh, I almost got mine to work except the "petite" distance between lines thingy..
                                Can I load the code in ruby code editor and launch? Cause nothing happends when I run your script.
                                  Please use it [or ideas in it] as you will - for example it doesn't always set the hatching at 45 degrees to where you might want just relative to the first edge of each face...
                                  There's no options for the angle or spacing - add a dialog for those?
                                  It's not optimized as it often makes more/longer edges than it needs to make the hatching but it was a quick kludge to make it work - to see what it does disable the closing parts that intersect/erase edges etc and use it on one face...
                                  It has ideas in it that should help you... πŸ€“
                                  PS: You have to have one or more faces selected before running it...
                                  • jolranJ Offline
                                    jolran
                                    You are so helpful. I can almost not believe it..
                                    Thank you TIG!
                                    I will continue with my script since I understand easier where variables are pointing to.
                                    See where I have gone wrong in some areas and use your script as a guidence.
                                    Thanks a million!
                                    • K Offline
                                      kyyu
                                      @jolran said:
                                      I'm getting it to work almost.
                                      vector.length=20.0
                                      The copied distance will always be desired length on the vectors line, but depending on the angle of diagonal the edges will not be same distance apart. So I guess I will have to do another compensation? Or is there some Quick fix like the last one(thank you TIG)
                                      I'm guessing will have to do a comparison between Diagonal, user(desired angle, here 45 deg) and somehow
                                      compensate the copy distance for that. Boy this is hard..
                                      Here is a example of finding the normal vector of a grouped line, using a cross product. The cross product of two vectors prduces a third vector, at right angles to the original ones.
                                      model = Sketchup.active_model
                                      ent = model.entities
                                      sel = model.selection
                                      line = ent.add_line [3,3,0], [5,5,0]
                                      group = ent.add_group line
                                      v1 = line.vertices[0].position.transform(group.transformation)
                                      v2 = line.vertices[1].position.transform(group.transformation)
                                      v = v1.vector_to v2
                                      # I used z vector as 2nd vector, but can try "face.normal" for general case
                                      normal_vec = v.cross([0,0,1])  #cross product to get normal vector
                                      pt = [0,0,0]
                                      demo = ent.add_line  pt, pt.offset(normal_vec)  #drew demo line representing normal vector
                                      demo.material = 'red'
                                      n = normal_vec
                                      n.length = 1
                                      g1 = group.copy
                                      g1.transform! n  # moved copied group using normal vector
                                      • jolranJ Offline
                                        jolran
                                        Hi Kyyu!
                                        Interresting. So you mean I use the 3rd vector for measuring? Or was it meant to be
                                        a method to get an angle 45 deg of the vector?
                                        Remember 45 deg is just an example for this particular hatching. The user must be able to
                                        choose any angle for the lines across the face.
                                        I will look into it more and see if I understand you code a little better.
                                        Thank you Kyyu.
                                        • K Offline
                                          kyyu
                                          @jolran said:
                                          Hi Kyyu!
                                          Thank you Kyyu.
                                          The 3rd vector would be your translation vector. In your code you have it as:
                                          vector=diag_vect
                                          vector.length= user_length
                                          It's perpendicular to what ever your final line is. Here, I just changed the line to a random new angle, not 45 deg. I set the length of the vector (distance of translation) to 1.
                                          I found this picture that explains cross product pretty well.
                                          • jolranJ Offline
                                            jolran
                                            Translation vector? The translation must be on the diagonal or the lines wont cover the whole face.
                                            I already have the rotation of lines, copy/translation set up. Except that the "bug" is that
                                            the translation distance doesent get 100% accurate if the face is very distorted.
                                            Maybe that is what you are trying to fix, and I don't see it.
                                            If thats the case sorry 😳 I'm a noob, you know.
                                            The angles of lines on the picture are the identical. Although they don't appear to be.
                                            • 1 / 2
