    Collection of my SketchUp + LayOut Work
    42 Posts 21 Posters 23.0k Views 21 Watching
    • bmikeB Offline
      bmike
      An update on the Round Barn project. I've modeled relevant joinery and connections as required by the engineering team that hired me to create these drawings:
      https://lh3.googleusercontent.com/-I3bxovoorfg/UBmKMN-lGPI/AAAAAAAATgA/yltmPVt9hRY/s800/8-1-12-roundbarn-section.jpg
      https://lh6.googleusercontent.com/-8GZDpPkXk7k/UBmKKp-G-ZI/AAAAAAAATf4/J5v7Tw_5Pno/s800/8-1-12-roundbarn-piersection.jpg
      https://lh5.googleusercontent.com/-ZEBb80SWwes/UBmKKLknItI/AAAAAAAATfo/HQPF9_BTSL8/s800/8-1-12-roundbarn-joinery3.jpg
      https://lh4.googleusercontent.com/-1QRw5WLwhKQ/UBmKKIjuVKI/AAAAAAAATfs/Et7ksT1c2IE/s800/8-1-12-roundbarn-joinery2.jpg
      https://lh5.googleusercontent.com/-MhQehokpMDA/UBmKIReO-MI/AAAAAAAATfY/8-s5q1NkJ7I/s800/8-1-12-roundbarn-joinery1.jpg
      mike beganyi design + consulting llc
      • hellnbakH Offline
        hellnbak
        I haven't commented on anything in quite a while (always sticking my foot in my mouth), and I know nothing about architecture, but I had to tell you how impressive your work is. The attention to detail is amazing!
        • pbacotP Offline
          That's such a classic section drawing. Leonardo would be proud. Thanks for the updates with the details and all.
          • allanxA Offline
            allanx
            The 3D detailing is pretty impressive here Mike...
            allanx
            [Portfolio](https://www.coroflot.com/designers/work-stream?id)
            • bmikeB Offline
              bmike
              Thanks for the kind words all... been a learning process, for sure.
              Those images don't pop open to the source... I'll have to do something about that.
              24x36 sheets crunched down, but they looked better on upload than they do now.
              Here's a gallery of them.
              • bmikeB Offline
                bmike
                another recent project:
                https://lh5.googleusercontent.com/-U-EwYdi2sLk/UFCialLe_II/AAAAAAAATsI/OmnhcXPFBxY/s800/barn1.jpg
                https://lh3.googleusercontent.com/-SP2sdU4ho7k/UFCiawfvwtI/AAAAAAAATsQ/a6GocncGtS8/s800/barn2.jpg
                https://lh5.googleusercontent.com/-zOCKblZaYyM/UFCibGoYdVI/AAAAAAAATsY/1Kd10KN3PV4/s800/barn3.jpg
                https://lh6.googleusercontent.com/-lYSQ76479nQ/UFCibd78eMI/AAAAAAAATsg/5ZtvTyKqa3c/s800/barn4.jpg
                https://lh4.googleusercontent.com/-nm_llXvalOo/UFCib99wz-I/AAAAAAAATsk/mkLVkK2IK14/s800/barn5.jpg
                https://lh6.googleusercontent.com/-hd3dqkROaKA/UFCicA6VTLI/AAAAAAAATsw/78lawNA-jcg/s800/barn6.jpg
                https://lh5.googleusercontent.com/-BlJIu6KX2mA/UFCicioq0pI/AAAAAAAATs4/Tww8g9UEz5w/s800/barn7.jpg
                • pbacotP Offline
                  Mike,
                  Thanks for posting. This looks great. I will have to come back and see more detail.
                  In terms of SU modelling: Right now working on a steel frame. Where do you usually start with your steel beams? Since mine is full (tapering) frame and only a preliminary I will probably make a profile of the whole wall to wall frame and push pull a reasonable likeness of the web and flanges--the dimensions of the building being the most important / most known element at this point.
                  Peter
                  • bmikeB Offline
                    bmike
                    @pbacot said:
                    Mike,
                    Peter
                    I usually do a quick model until the details / sizes are pinned down, then adjust and model accordingly.
                    I use the Bolt Maker Plugin to generate the bolts / nuts.
                    Working on another small building now. Just got it back from the engineer with updated sizing for floor girders and principle steel roof rafters. I'll be giving it similar treatment as this (copying in some of it actually...).
                    • RichardR Offline
                      Richard
                      Yelling with appreciation! STUNNING WORK MATE!!!!!!!!
                      Clean, clear and so easily read and understood!
                      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                        😲 β˜€
                        Many more in colors here πŸ˜‰
                        http://mcnorlander.files.wordpress.com/2011/07/open-saw.jpg?w=746&h=1181
                          By Bmike
                          [flash=560,315:1v08qvl1]http://www.youtube.com/v/fFIR6oQPny8[/flash:1v08qvl1]
                          • bmikeB Offline
                            bmike
                            Thanks Richard!
                            • bmikeB Offline
                              bmike
                              Thanks Pilou!
                              I need to work on Part 2... have to find quiet time to sit and record and edit.
                              • bmikeB Offline
                                bmike
                                This:
                                Came from the drawings I posted earlier:
                                • pbacotP Offline
                                  That's great!. I hope we see more of the overall structure as it goes along. I'd expect to see more snow on the ground.
                                  • RichardR Offline
                                    Richard
                                    WOWWWWWW! That's looking AMAZING mate! Looking forward to watching the progress. πŸ˜„
                                      Sketch007
                                      I watched you Timber Framing at basecamp video. You used two plugins that look really helpful. The color coded one and the "white out." Are these not available to the public? They were only given out to people attending base camp? Are they available for purchase anywhere?
                                      m@
                                        Extremely nice illustrations, earned your money and then some.
                                          rodrigo_cerci
                                          Really awesome work man! Lots of stuff there πŸ˜„
                                          • bmikeB Offline
                                            bmike
                                            m@
                                            Thanks.
                                            TIG wrote WhiteOut for me.
                                            SDMitch wrote the Color by Face plugin.
                                            Both are members here - I'm sure they would share if asked!
                                            • 2 / 3
