    Observer question
    5 Posts 3 Posters 466 Views 3 Watching
    • P Offline
      Pout
      must me the heat here but some how i'm puzzled.
      I want to remove an observer.
      It's added like this:
      Sketchup.active_model.selection.add_observer(MySelectionObserver.new)
      and here is the observer code:
      class MySelectionObserver < Sketchup::SelectionObserver
      def onSelectionBulkChange(selection)
      #code to execute when the selection changes
      Now how do i remove this observer?
      Thx!
        Make an enduring reference to the observer as you set it...
        @@myselectionobserver=Sketchup.active_model.selection.add_observer(MySelectionObserver.new)
        later on to remove it use...
        Sketchup.active_model.selection.remove_observer(@@myselectionobserver)
        OR if the parts of the code are not within the same class/module use a global $ BUT make sure it's a 'unique' name - like $this_is_pouts_extra_special_selection_observer so no one else's similar observer by the same name gets messed with!!!
        • Dan RathbunD Offline
          Dan Rathbun
          The API states that Selection.add_observer returns a boolean true || false indicating sucess.
          perhaps:
          @@myselectionobserver = MySelectionObserver.new() Sketchup.active_model.selection.add_observer(@@myselectionobserver)
          I'm not here much anymore.
            Dan you are right - I rushed that off without thinking πŸ˜’
            Your way is correct - make a new observer, apply it... remove it!
            ` @@myselectionobserver = MySelectionObserver.new()
            Sketchup.active_model.selection.remove_observer(@@myselectionobserver)`
            IS the correct way...
            • P Offline
              Pout
              suberb, and this on a sunday!!!
              Thx tig and dan, much appreciated!
