    Conversion sketchup/vectorworks
    4 Posts 2 Posters 1.9k Views 2 Watching
      coni9
      hi!
      i'm new in this forum and i have a simple question... i try to import some sketchup model into vectorworks 2008 but i can't do it properly... my model appears with a lot of triangles and i cant really work on it after...So i would like to know the simpliest way to import my sketchup model to vectorworks? what settle i need to do? if you have any suggestions i'll be happy to try it!
      thank you every one!
      nicolas
      • Alan FraserA Offline
        Alan Fraser
        Hi Nicolas,
        What format are you using to export to Vectorworks? Whichever one it is, make sure that in the Options (bottom right corner of the export box) that 'Triangulate all faces ' is not checked.
        3D Figures
          coni9
          hi alan!
          i'll explain how i import a sketchup file to vector works 2008... in fact when i import it using import sketchup file, nothing appear on my screen so i export my sketchup file to a 3DS's file and then i import this 3DS file into vector works... and thats when i have all the triangle on my model ... so do you know the actual way to directly import sketchup file in vector works?
          thank you
          nicolas
            Alan Fraser
            I'm afraid that I don't use Vectorworks, so I don't know of any direct import option. However, you have answered your own question by saying you export to 3ds. A 3ds file HAS to be triangulated, because the format does not support quads. Therefore it's bound to come into vectorworks as triangulated...unles VW has an import option (like SketchUp) in which you can choose to have all triangulations removed from coplanar faces. You would be better using obj format as a go-between....if VW can import obj files...because it will not triangulate.
            3D Figures
