    Ruby Hotkeys Plugin?
    26 Posts 5 Posters 4.8k Views 5 Watching
      sergey2402
      Can I through the Ruby script to execute the command, appointed in Sketchup on "hot keys"?
      For example.
      I have a plugin “Weld”. And for him I have “hotkeys” Ctrl+W.
      Then in the Ruby Console I do - "execute Ctrl+W " and will execute the plugin “Weld”.
      Is it possible?
        Jim
        To exeute the weld plugin, you would enter "join_edges" in the Ruby Console because the name of the method which weld defines is named join_edges.
        Look for the UI.menu() {} code in other plugins to find the name to use to call from the Ruby Console.
          sergey2402
          I mean another thing.
          It does not matter which plug-in to execute. Maybe "Weld", maybe "Beld" or maybe "Weld-Beld". Does Ruby ability to perform the command associated with the "hotkeys" assigned to Sketchup?
          I don't want to know the name of the method, which plugin defines. I only know one thing - "hotkeys", which I defined in Sketchup, the plugin can be arbitrary.
            Jim
            Then no. At least not without this: http://code.google.com/p/eventrelay/
              sergey2402
              Thank you. I'll try it
                sergey2402
                Is there a theoretical possibility to write the text of Ruby-script, which emulated a pressing hotkeys defined in the SketchUp by the user?
                  On a PC you can use Wscript.shell to simulate specific keystrokes... BUT why would you want to do this ??
                  • Dan RathbunD Offline
                    Dan Rathbun
                    use the Sketchup.send_action method.
                    I'm not here much anymore.
                      sergey2402
                      I know some of numeric values applied to “Sketchup.send_action( )"
                      For example, some of them:
                      10527: "Shift+Ctrl+E"
                      10526: "Shift+Ctrl+W"
                      -7892: "Ctrl+Y"
                      21101: "Ctrl+A"
                      21065: "A"
                      21096: "C"
                      21019: "E"
                      21074: "B"
                      And so on…
                      But I don’t know the numeric values for the key combination, for example, "Shift+Ctrl+A" or "Shift+Ctrl+B" or "Shift+Ctrl+C", etc.
                      Where can I find numeric values for these (and similar) key combination?
                        sergey2402
                        I will answer your question. But, with my “excellent knowledge of English”, I'll be a long time to formulate my ideas.
                          Dan Rathbun
                          Numeric arguments only work on Windows, not on Apple Mac.
                          Concentrate on the command (not the key combos,) and use the string arguments for send_action.
                          Example: Ctrl+Shift+W = Camera Zoom Window, so:
                          Sketchup.send_action("selectZoomWindowTool:")
                          Any user can change the shortcut key combos for commands.
                            sergey2402
                            Thank you very much for you paid me attention. But my question is different.
                            Where can I find numeric values for these ("Shift+Ctrl+A" or "Shift+Ctrl+B" or "Shift+Ctrl+C") key combination?
                              @sergey2402 said:
                              In a nutshell - the ultimate goal to create a Ruby script called "hotkeys buttons on the toolbar"
                              I mean, hotkeys are not built into SketchUp. I mean user-defined any hotkeys for any plugins.
                              You can define hotkeys for any menu or toolbar element - that include those the belongs to ruby scripts?
                                sergey2402
                                Sorry, I do not understand. That was the question? Or was it your help?
                                Of course, my English is "excellent", but I understand it is very bad. 😳
                                  sergey2402
                                  In a nutshell - the ultimate goal to create a Ruby script called "hotkeys buttons (or icons) on the toolbar"
                                    Window > Preferences > Shortcuts
                                    Filter for the tool/ruby required.
                                    Set shortcut key[s] to it.
                                    Note that some items only appear in the list if there is a suitable selection - e.g. to shortcut to 'Reverse' face as seen in the context-menu, you must first select a face then open Preferences - if no face is selected then the 'Reverse' doesn't appear in the available items to shortcut to...
                                    Provided your plugin has some sort of menu presence you can shortcut to it by 'name'...
                                      Jim
                                      Serge, you are talking about Windows Automation with Ruby.
                                      The "Ruby Way" is to use the Ruby Win32ole library. (Search Ruby Gems about using Ruby libraries in SketchUp-Ruby.)
                                      Alternative to win32ole, some plugins use the WShell.SendKeys() from a .vbs script to do the automation. (I use this in Save as Previous Version.) Windows Powershell can also use the SendKeys function to automate Windows.
                                      There is no "perfect" solution.
                                        sergey2402
                                        Unfortunately, for me it is too difficult. I'm just a civil engineer, not a programmer. I really like SketchUp and I found it very useful. I just want a little to tweak it for me...
                                          sergey2402
                                          In the menu Window > Preferences > Shortcuts I redefined the letter "H" from the “Camera/Pan” to plugin “Pipe Along Path”.
                                          I drew the lines, selected them and pressed on the keyboard the letter “H”.
                                          Plugin “Pipe Along Path” been executed. BINGO!
                                          I drew the lines again, selected them and run Window > Ruby Console.
                                          In the Ruby console I wrote a string “Sketchup.send_action 10523” and pressed Enter
                                          (I know - the value of 10 523 corresponds to the letter “H”)
                                          And what I see as a result?
                                          I see a HAND (Camera/Pan)!!!
                                          What nonsense is going on?
                                            What makes you think that 'Sketchup.send_action 10523' is an 'H' ???
                                            10523 == 'Moves the camera viewpoint while maintaining view direction' [PC only!!]
                                            Remapping a shortcut key has no connection whatsoever with that key's previously linked command ???
                                            You've simply changed 'H' to be the shortcut key for 'PipeAlongPath'...
                                            The 'send_action' still calls the fixed linked-command!
                                            IF you want to use the 'H' to execute its linked-command use a Wscript or similar key-emulator BUT, oh BUT, why are you trying to do this weirdness ?????
                                            Why not simply invoke PipeAlongPath directly ???
                                            • 1 / 2
