    Lines not intercepting ( Accuracy bug ?)
    5 Posts 2 Posters 415 Views 2 Watching
      Tuga703
      I haven't searched much but i'm currently having a problem with lines that won't intersect when all the start points are at the same height.
      http://img52.imageshack.us/img52/5403/sketchupbug.png
      All lines should intercept at the same point
      Any help Welcome
        The file would be much more helpful. What if the start points are at the same height but the end points are not?
          Tuga703
          Here it is, thanks for the quick reply by the way
          Wheel 300 17 19 plus wheel arch.skp
            So what I thought... See the Z values of the endpoints of two lines there (Use the leader text label tool to get the co-ordinates of any point). One has them both on the same red/green plane but the other one has one endpoint a millimetre lower than the other (and than the endpoints of the other line).
            Maybe the easiest way to draw coplanar lines would be to draw a horizontal face first and use that as a "drawing table". SU will try to snap onto that face.
              Tuga703
              I was unable to make a drawing face either, but I installed a toggle units plugin which gave me more accuracy with the coordinates so now they intercept.
              Thank You
