    Sticky text.....??????
    layout
    17 Posts 4 Posters 3.0k Views 4 Watching
    • utilerU Offline
      utiler
      Hey guys, this is giving me the #$@%(!!!!
      See the attached screen video. I have loaded three OTF font types that I have decided to use exclusively for my work: Light, Medium and Bold types....
      When I go to enter text and select either Medium or Bold it defaults to Light type. Bloody annoying!!!!
      Any ideas? I've tried loading TTF font files also but no luck.... maybe a bug. 😞
      LayoutIssue-Font_ID.swf
      Just Curious...
        ArCAD-UK
        Haven't viewed your SWF.
        Is the difference in weight so slight that you can't see it unless you zoom in?
        Are the font weights showing in a print out / export?
        Do you get the same problem with "standard" fonts?
        Are you trying to use a non-standard font?
        Do the font weights appear correctly in other software?
        • utilerU Offline
          utiler
          Thanks Trevor,
          They do work on other programs... Word, Excel, etc.
          Non-Standard Fonts...? not sure what you mean; they are otf files that are sold by reputable Foundries.....
          Its not that the difference is so slight; the problem is that when I click onto say 'Bold' it reverts to 'Light'. When I click onto Medium' it does the same, reverts to Light so I don't actually have the option to see what Bold or Medium look like on screen or in an export....
          πŸ‘
          Just Curious...
            ArCAD-UK
            Just checked some of my installed fonts and found the same problem that LO will not allow its selection even though it is listed under "Family" e.g. "Berlin Sans FB Demi Bold". πŸ˜• One for Google me thinks.
            • utilerU Offline
              utiler
              That's right Trevor; if you have a family of typefaces loaded into windows Layout seems to only use one.....
              Just Curious...
              • RichardR Offline
                Richard
                Hmmm? Thats a weird one mate! Could it have something to do I wonder with "bold" being selected or deselected as an override?
                BUILTBRAND.COM.AU
                • utilerU Offline
                  utiler
                  Hey Richard, I don't even have the option to choose bold!!!!! It just defaults to Light....
                  πŸ‘
                  Just Curious...
                    jhauswirth
                    Can you list the specifics of the font (font family name) that are not working correctly?
                    The font is needed to debug the problem.
                    • utilerU Offline
                      utiler
                      Thanks John. [I think... ❓ ]
                      This is the particular font type that I'm having trouble with.
                      http://www.foundrytypes.co.uk/
                      specifically the Sterling font.
                      Also have problems with Linotype Ergo
                      http://www.linotype.com/1023/linotypeergo-family.html
                      cheers,
                      πŸ‘
                      Just Curious...
                        ArCAD-UK
                        Andrew, If you start a new blank LO can you select and use each one of the fonts e.g. new drawing for each font? Today I can load "Berlin Sans FB Demi Bold" in a new drawing that definitely wouldn't load the other day, trouble is I can't remember which drawing I was in at the time.
                        • RichardR Offline
                          Richard
                          πŸ‘
                          Mate what I'm meaning is could the text box properties be set to bold or light via the BOLD button and this not allowing the selection via the text style dialogue?
                          BUILTBRAND.COM.AU
                          • utilerU Offline
                            utiler
                            Good point Richard, I'll check. πŸ‘
                            Just Curious...
                            • RichardR Offline
                              Richard
                              Any luck mate?
                              BUILTBRAND.COM.AU
                              • utilerU Offline
                                utiler
                                Hey Rich, was away from the office yesterday....
                                Checked the BOLD setting and no luck. I even loaded all the font types I have in the family only to find that the text function now 'sticks' to the first font in the family...
                                [see attached].
                                LayoutIssue_wiit_text_sticking.swf
                                πŸ‘
                                Just Curious...
                                • RichardR Offline
                                  Richard
                                  Ah! Wow that's really weird! Hmmmm? I'm out of ideas - good luck with the Googies!!! They'll sort it!
                                  BUILTBRAND.COM.AU
                                  • utilerU Offline
                                    utiler
                                    I'm wishin too.....
                                    πŸ‘
                                    Just Curious...
                                    • utilerU Offline
                                      utiler
                                      Any luck with this?
                                      πŸ‘
                                      Just Curious...
